Question about Dryers
Once the dryer has started the drying process the gas comes on like it suppose , then after reaching tempture it shut doen not to come back on the glow plug come on but it will not light, so the dryer can completely dry the cloths.
  • 525 Answers
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
Have a whirlpool dryer, le9380xtwo, it gets hot and shuts doen, i checked the system and the system throstate, opens up, when it cools down it makes contact again, i think it is the cycling themostate to...
The cycling thermostat is supposed to shut down when it reaches a certain temperature, cool down and then make contact again when it cools down and starts the process all over again. What exactly is wrong with the dryer?
May 30, 2012 | Whirlpool Dryers
My gas dryer is working but there is no heat so my clothes will not dry. I've got all these wet clothes and I need to get this dryer to heat up. Please heat!
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Dryers
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Turns on but. Will not heat upb
The areas that come to mind is the ignitor and/or sensor has gone bad The most unlikely is the gas valve but it is a possibility. I check for a thermal fuse on your model It does not come with one. That eliminated another cause.
Attached is a picture for reference.
When the dryer is turned on, the ignitor ( #74) will start to glow and in a few seconds to a bright orange color. The sensor ( #79) which is located on the outside of the flame tube, detects the heat intensity from the ignitor. Once the ignitor has reached its limit when operating correctly, the sensor will give a signal for the gas valve to open and release gas through the burner where the ignitor will light the gas. This process repeats several times when drying a load.
Defective ignitors will either have no glow or the will glow a little bit.
Hope this helps you out.
Always you caution when working on appliances.
Nov 16, 2010 | Frigidaire GLGQ642A Gas Dryer
Dryer start up fine then the gas turns off as ignitor continues
Hi Jim. Perhaps this will help you.
The burner assembly consists of the gas valve, the igniter and sensor, and the thermostats. The gas supplied to the appliance is turned on and off by the gas valve, as follows:
  • First--when you close the dryer door, set the timer, and press or turn the Start button--the motor starts. When it reaches full speed (in about a second) a switch on the motor turns on, which allows the electricity to flow through a simple thermostat to one side of the gas valve.
  • The gas valve then sends power to the igniter, which glows bright orange.
  • As heat and light from the igniter warm up a sensor that's right next to the igniter, the sensor circuit opens, then supplies power to the other side of the gas valve. This completes the circuit and opens the valve.
  • Once the valve opens, the gas rushes out and the igniter ignites it. As the gas burns, it keeps the sensor warm, which keeps the gas flowing.
  • When the dryer reaches the pre-set drying temperature, a simple thermostat turns off the flow of electricity to the gas valve and therefore turns off the gas.
  • When the temperature in the dryer falls about 20 to 30 degrees, the thermostat again allows the electricity to flow through to the gas valve, and the cycle starts over.
If you selected the Automatic setting, the cycle continues until the clothes are dry, then the timer advances and turns the dryer off.
If you selected a timed setting, the cycle continues until the time has expired, then the timer turns off the dryer
Jul 27, 2009 | Dryers
Low dry temperature
check your air flow it could be a clogged or pinched vent pipe
Dec 20, 2008 | Maytag Neptune MDG9700A Gas Dryer
Whirlpool Electronic Gas Dryer
I would suggest cleaning your moisture sensors. If you stick your head inside the open door and look straight back towards your lint screen, you will see 2 silver bars. These are your moisture sensors. They can get a coating on them over time. Once this occours, the moisture can't reach the sensor and the machine thinks the load is dry and shuts down. Using the abrasive side of a sponge or even some fine grit sand paper, run it back and forth each of them. You should be good to go if you've already cleaned the area underneath the lint screen, made sure the hose from the dryer to the wall is not kinked, folded over or smashed and you have good airflow coming to the outside of the building.
Jun 18, 2008 | Dryers
Dryers Logo
119 people viewed this question
Top Dryers Experts
