Question about Canon PowerShot SD30 Digital Camera
Canon powershot sd30 digital elph
My camera lens did not retract back in when I shut off my camera. So now it won't turn on either. It's just stuck! HELP
  • stacie1 Sep 10, 2008
    The lens won't retract when turned on & off, screen is black and when turned on there are 4 quick beeps, a green flashing light and then it shuts off.
  • Anonymous Dec 07, 2008
    same problem. it sucks.
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Posted on Jun 24, 2008
    Problem Solver:
  • 5 Answers
Most lens errors on the SD30 are caused by the camera being dropped or bumped while the lens is extended. The impact causes the brass pinion gear to shear teeth of on the ring gear that extends and retracts the lens assembly. Even if the teeth are OK the impact may cause the tracking pins on the inner lens housing or front lens carrier to jump their tracking groves. About the only solution is to disassemble the entire lens assembly; replace the inner housing that contains the ring gear, or realign the tracking pins in their proper groves. Fortunately I have written an extensive repair manual that covers the step by step procedure of doing just that. It is available by emailing Jim at kilnmanii@aol.com.
Posted on Dec 13, 2009
How to fix Powershot Elph 530S so that the lens retract all the way when powering off
From the way you describe the problem it appears that the retraction mechanism has become out of line. I think that as you can hear a clicking sound the mechanism is working but not engaging with the lens. Try gently applying slight pressure on the front of the lens this may help to re-engage. You may need to consider a trip to the repair shop.
Jul 11, 2014 | Canon PowerShot Cameras
How do i fix a Lens error in canon powershot elph 300hs?
None of the suggested solutions worked for me and my Elph 300HS. However, I took it apart, removing the back. There was a screw inside holding on the front panel which I could not budge no matter what, so I gave up. I put it back together, reinserted the battery, powered on and voila, it was back to normal. Perhaps disconnecting the battery for a while was key. Had I not tried the multi-step approach suggested, it would still be stuck.
Feb 23, 2012 | Cameras
When i turn on my camera it beeps and the screem goes black saying.... Lens Error, Restart Camera.. how do i fix this?
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Apr 03, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon power shot sd30 digital glph
There is nothing for the user to here.
If the camera is lessthan one year old then returnit to vendor or contact Canon customer support for replacement.
If more than a year - simply replace the camera
Aug 26, 2008 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Canon PowerShot SD30 Digital Camera Logo
312 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
