Question about HP DeskJet 940c InkJet Printer
Color printing i recently put a color ink cartridge into the printer but it won't print in color. the computer says it is set to print in color but it doesn't... the cartridge is in the right way and the black color works fine but i don't know what to do anymore...
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Is this still current?
Posted on Aug 19, 2008
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
Won't print in color
How long have you had color ink cartridge in the printer for? Have you triple checked you have set the settings to print color? If it still persist then the possibilities are your ink color cartridge is out of ink? have you made sure it's installed properly?
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 14, 2012 | Canon Pixma MP480 All-In-One InkJet...
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I just put all new ink in my printer and will not print. Unplugged it to re-boot it, still won't work. If i copy something by hand will not print, if i copy something from computer it does not...
be sure that you remove the tape from the cartridges before you insert it in the printer, it has a color pink attach to the tape remove it slowly then insert the cartridge to the printer,
Aug 03, 2011 | Computers & Internet
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
My hp officejet 9130 will not print in color.
Try runing the printer test and see if colors print. If they don't your color cartridge is cloged. You can try to set the print head(copper strip on bottom of cartridge) on a damp paper towel for a while to try and unclog the head. You should see the colors on the towel. Dry head off and try again. Hp uses water base ink and it will dry up after setting for awhile. The printer knows it has ink in the cartridge, because it will try to print, so it has to be the print head.
The print head has two lines of holes or jet for each color and if some of them are cloged, it will look striped or missing colors.
Mar 05, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP DeskJet 940c InkJet Printer Logo
77 people viewed this question
Ben Johnson
