Question about Nikon Coolpix L11 Digital Camera
"Lens Error", then camera shuts off
My kids were using camera and dropped it from ~18in to countertop. Now lens is out slightly and error message on screen "Lens Error". This persists for a minute or two, then goes off. Suspect gear-driven (guessing) lens is jammed, or jumped teeth - so won't properly initialize.
  • Anonymous Jun 30, 2008
    When I turn my camera on, I get the "lens error" message. It has just been sitting on my desk for the past month, unused. Thanks, Julie
    Guru:
  • 1,049 Answers
There are known issues with the lens on this camera, but it's also only a $100 digital camera. Most of the time if you call customer support they will replace it without question; in my case, after much complaining and moaning they even agreed to do it outside of the warranty. It is a design flaw, they DO KNOW it's an issue, and talking to sales people at stores I believe they get a lot of them back.
Posted on Jul 30, 2008
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
Canon sd850 is lenz cover partialy closed. Turn on says " lenz error. restart camera. Then shuts itself off.
u have see the user guide if its not help then reset your camera on the factory setting
thanx using fixya i hope it can help u
Sep 06, 2008 | Cameras
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Lens error message? Worked fine the last time I
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 27, 2010 | Canon Powershot A2000 IS Digital Camera
Lens wont move
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
E18 Error
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
Feb 11, 2009 | Canon PowerShot A400 Digital Camera
Lens Error!
Hi I use to be a camera technican for samsung repairing small camera's like yours.It is a very common fault 90% unfortunatley of lens errors are the users fault not the cameras. The lens error means the lens is jammed, usually by a slight knock while the lens is out or a bit if debri like sand getting into the lens's moving parts. If it is still under manufacturers warranty send it in for repair. If the camera is clean and looked after with no scratches, dints or abrasions on the lens or camera body you will have a chance to get it fixed under warranty for free. If it is scratched and dinted and the purchase value of the camera is around $250 it may cost you around that to get it fixed. Good luck
Jan 12, 2009 | Nikon COOLPIX L10 Digital Camera
Two cameras and two lens erros
I don't think either camera is worth the over $100.00 that it will cost to fix. However, look at my posts on this problem of lens errors. By forcing gently the lens in or out when you start the camera and shut it off, it may get the lens to work again.
This may damage the camera even further, up to you, and may be worth a try.
Apr 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
I bought two of these on clearance and gave one to my in-laws. She suspected that one of her kids may have dropped the camera or pushed in the lens. I don't remember which lens error number had shown up, but I dis-assembled the camera to find out what the deal was. If I remember correctly, there is a way to manually turn the gears to put he lens back out. I left the lens out and turned it on and it worked perfectly. Fair warning though. It is VERY IMPORTANT not to touch the contacts for the flash EVEN WITH THE BATTERIES OUT!!! God did it hurt like hell... unfortunately it is fairly easy to do and I must have accidentally done it about 4-5 times while messing with it..
Sep 05, 2007 | Kodak EasyShare C330 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
