Remove the left side cover to expose the flywheel and ignition module. Set the module pole gap by turning the flywheel magnets under the module, insert a thin business card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps do not close up at any point. Remove the ignition switch wire from the coil connection (not the pole ground), and install a fresh spark plug gapped at 0.020". Try again for spark. If nothing, replace the module. Hope this helps!
