Connecting netgear 108 mbps super wireless adsl router
Hello there,
I just bought a router and tried to connect and configure it but it would not because i do not have a phone line. What do i do?
I noticed that the router i bought is a modem router and only needed an adsl line. I cannot connect the router to my broadband connection because i already have a modem from my ISP. So, i'll have to sell the router and buy a wired router without modem for me to successfully complete the installation and configuration.
Cheers!
Posted on Jun 25, 2008
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
What do u need to connect on the NetGear WPN824 RangeMax 108 Mbps Wireless G Router for it to be fully fuctinig
most wireless routers are the same. They have a WAN / Internet port that connects to your internet providers modem and four ports to connect your computers to, this is for wired configuration. For wireless you need to setup your security key, and network name(SSID) , see link below on how to connect to router, i wrote up yesterday . Once you have completed this step you can use your laptop to browse for wireless networks and press connect on your home network once the computer finds it. click here for some configuration help tips on how to connect to your router. Please note most routers will work simply connecting them, and trying to connect to "Default" or similar without any security. Some do not allow this and you need to create a security key and enable the wireless via the same console prior to use. Hope that helps you.
Aug 30, 2010 | NetGear Computers & Internet
WG111 54 Mbps Wireless USB 2.0 Adapter is not connecting with the third party adsl router when the computer is starting for the first time, why?
That is because your motherboard may have no native support for USB 2.0. Try connecting the adapter to another PC. If this works, then, there is your answer.
Nov 20, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
About 108 mbps wireless router wgt624 netgear
HOW CAN I INSTALL MY NETGEARN 108Mbps WIRELESS FIREWALL ROUTER WGT624 v2.
Jan 23, 2009 | NetGear CG814M Wireless Cable Modem...
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Internet connection
Different internet providers have different requirements for connecting routers to their equipment. Can you provide the name of your internet service provider?
Dec 18, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear WPN824 wireless router
there is no reason why you shouldnt connect at 108 mpbs, so there are only a coulple of things you can try, the first is to change the channel that your router transmits on within the router settings, although this should automatically be done by the router when it comes up against any interference. Secondly try the adapter in a different usb port as USB 2.0 should be used and the port may not be recognised as a high speed port. Double check the router connection transmition speeds is set at 108 mbps; as it would also be able to transmit at a lower speed of 54 mbps so as to be backward compatable with 54 mbps adapters
Jun 30, 2007 | NetGear RangeMax WPN824 Router
NetGear Super G 108Mbps Wireless Firewall
If you are connecting wirelessly, then it's more than likely that your wireless card or usb dongle cannot connect as you router is probably set at 108 mbps. Your receivers are more than likely only capable of connecting at 54 mbps so change the streaming rate on your router to 54 mbps. This will not alter your internet connection speed as the 108 mbps only refers to the rate of streaming speed on your local area connection (from one pc to another)
Dec 30, 2006 | NetGear Super G 108Mbps Wireless Firewall...
Computers & Internet Logo
David Payne
David Payne
