Question about Toshiba PDR-3320 Digital Camera
Locked lens I have a Toshiba PDR-3320(digital) camera. It does not focus because the lens is locked and will not move in and out to focus. Cannot even manually move it. Can you help me? Thanks
  • Anonymous Mar 14, 2014
    Toshiba pdr-330 camera turns on, lens cover won't open. You can hear the motor run when you move the switch followed by a series of beeps, but menu windo still says lens cover
  • 231 Answers
Your camera needs a new lens assembly.These lenses are not repairable .They can only be replaced.
Posted on Jun 23, 2008
Hi,lost my CD for my Toshiba PDR-3320 any where I can download it for free? Old laptop died and I need to re-install the software so I can post photos.Thank you!Kev
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( ).
Oct 09, 2010 | Toshiba PDR-3320 Digital Camera
Camera won't focus
I think you're camera has had it. You could try the Toshiba web site follow links for support and downloads to see if there's a firmware upgrade which may solve the issue.
I've checked the specifications and I wouldn't spend anything on repairing it. I'm afraid its just not worth the outlay. You could probably get a good camera with a higher specification second hand for less than an hours repair bill.
Jul 19, 2010 | Toshiba PDR-3320 Digital Camera
First thing do you charge for this if so i can not do it When looking through the camera lens to take a shot it is bluery and you can not tell what it is. toshiba PDR 3320 digital still camera
No charge.... FREE!
The eyepiece has no diopter setting.
However, if you press the shutter button "halfway" down (don't press it all the way). the picture will come into focus.
After you focus, then press the shutter button all the way down.
This will work...
Sep 08, 2009 | Toshiba PDR-3320 Digital Camera
Toshiba PDR-3300 Lens cover message
Hi Judy, thanks for coming to FixYa.
Sorry no one has gotten to you sooner. Your manual mentions this and this is what it says to do:
Turn the camera on and move the lens cover switch to the open. Then your camera should operate normally. Let me know if that helps.
Feb 16, 2009 | Toshiba PDR-3330 Digital Camera
Memory card locked
pull the SD card from the the slot and it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jan 11, 2009 | Toshiba PDR-3300 Digital Camera
Help on PDR-3310 can not power on and no displace on LCD
Push lens assembly back into camera gently yet firmly with your thumbs until you hear a click.
May 14, 2008 | Toshiba PDR-3310 Digital Camera
Lens not moving
The lens mechanism is shot. Depending on the age and possible cause of the condition- has it been dropped? I would think replacing the camera is a better option than trying to get it repaired -which I think is not a likely option
Jul 25, 2007 | Toshiba PDR-3320 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus. 4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Toshiba PDR-3320 Digital Camera Logo
78 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
