Question about Maytag CWG3600A Gas Single Oven
Lost directions to use the self-cleaning feature on my oven
30 inch stove
  • bkiss359 Jul 23, 2008
    We started the cleaning cycle, but don't know how long it takes and hw we will know when it's done.
I have same problem. When I hit clean, the lock engages and the oven acts like it is preparing to clean and then everything stops.
Posted on Sep 17, 2008
Where can I find an electric range with depth less than 28 inches
Bertha, most stoves are going to be anywhere from 26" deep to 29" deep. Most any stove that I have used or worked on has never been a counter depth stove unless it was a slide in or a drop in stove. When I went to GE's website, I did not many stoves that were less than 28" deep until I got up to $1000 in retail pricing. The only one under that price that was less than 28" was also only 24" in width. Hope this helps!
Dec 08, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven only heats to 215 degrees will not get any hotter.
Sounds like the heat sensor is bad. I'm assuming this is an electric oven. On the inside back wall of the oven you will see a metal rod sticking out. Unplug the stove, take off the back cover and you'll see where it's attached. Unscrew the keeper and pull it out through the back. Unplug it from the wiring harness.
Apr 15, 2012 | Ovens
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
Need to take bootom burner out of stove
Make sure you unplug the range.
There should be 2 screws on each side of the heating element, usually these are hex heads.
Remove the screws and gently side the heating element out a few inches.
You should then be able to unplug the wires to the element.
Hope this helps you
Jan 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Are you working christmas night? we had a small
Clean that oven by hand before you cause more problems...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Frigidaire Ovens
The circut breaker on the rear of the stove trips and must be reset every time the oven self cleanui=ing is engaged (Model # PLES399EC). How can this be fixed or prevented?
The best thing to do is not use your self cleaning feature....
Whoever invented that has caused way more problems then it solved...
It is a featured designed pruely to sell product because people are inherently lazy and because it burns up good products and then they get to sell more...
heatman101
Nov 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How to self clean the oven?
Get some easy off oven cleaner and go by directions. Using the self clean function damages expensive oven controls. My opinion. Electrolux stove service manual
Oct 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag CWG3600A Gas Single Oven Logo
202 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
