Question about Gigabyte GA-7VKML Motherboard
BIOS SIr, My system clock will not be update when i start my computer one day after, i have change New Cells two time but its still same problem kindly tell me this solution. thank you
  • 144 Answers
Check the Battery Connectors are ok & not rusty. Load Setup defults in BIOS. Change the date from BIOS.
Best Luck..
Posted on Jun 23, 2008
Always resetting the clock
first run bios update program
change new brand battery
if your system is laptop check adapter & main battery
else desktop cross check new smps
if smps problem power off system restart
Feb 20, 2014 | Computers & Internet
Lock ibm bios 0271 error
You need a replacement battery for the CMOS system on your computer.
The CMOS system contains the BIOS settings configuration and also runs the real time clock. If the real time clock does not stay in sync, this can have a negative affect on your installed operating system ( for example, a windows computer will not allow ANY system updates if the difference between your system time date, and the update servers current time and date is offset for 24 hrs. or more)
Oct 29, 2013 | Lenovo ThinkPad T410 Notebook
Bios error - won't boot - clock or BIOS time keep getting altered
Firstly, replace the small watch battery on the motherboard.
Secondly, look at the motherboard and get the model number off it, example Msi 6472-1. Then look up the motherboard model on the manfactures website, and there should be a updates or update bios tab or link. Click and follow on screen instructions. Some manfactures automatically identify your board on their update page.
In the system settings, press del on boot up, ensure clock speed is set to auto or to manual what it should be at, same with the ram settings.
As a last resort, sometimes dust build up on the processor pins or ram causes silly errors, simply remove, safely clean and reinstall.
Lastly, is there a application in the task menu of windows that can alter the clock speed depending on usage? Check settings.
Sep 05, 2012 | Systemax SYX SG-125 Gaming PC - Intel Core...
Hi, I have a dell studio 1535 and the bios clock runs very fast. In one hour the clock pass few days. I try updating the bios, set to default values and nothing changes. This is a CMOS...
I dont think it is a cmos issue because i replaced the cmos battery and it did not help my clock. I also had dell fix the motherboard and it worked for bout 7 months unfortunately after my warranty was up. Til this day my clock last no longer then a few hours until it reverts back to the time i changed it to.
Dec 27, 2010 | Dell Studio 15 Laptop
Some time ago, after installing Windows 7, my Dell 1525 started changing internal clock as it wants: yesterday there was 2010, today is 2021... But it wouldn't be a serious problem if the laptop worked...
Go to http://support.dell.com and download the latest BIOS update for your system.
Please remember NOT to power down your system when flashing the BIOS.
Reset your system time inside windows and see if system time won't change by it's own. If time is stable, then you fixed it. If system time changed again, the you have to other choice but to replace the CMOS battery.
Jun 08, 2010 | Dell Inspiron 1525 Laptop
Where can I ajust the clocktime in bios?
right click on the time and select "Adjust Date/Time"
Then Click the "Internet Time" tab at the top.
Click "Change settings..."
Select "time-nw.nist.gov" and Update
I hope this helps.
May 31, 2010 | Office Equipment & Supplies
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
I have a e system desktop the clock keeps running late
Computers have an internal battery on the motherboard that helpd the board retain certain data when the computer is off. If the battery is low or dead it will cause this problem. The easiest way to replace the battery is to open the side of the computer when it is off and remove the battery from the battery holder on the motherboard. The battery looks just like a watch battery. Replace it with the same kind of battery (available at most drug stores) once you have replaced it turn on your computer and reset your clock.
Dec 29, 2008 | E-Machines eMachines Desktop PC
How install bios
you need to reboot your system with the help of mother board cd or driver. default yuou system.
Dec 12, 2008 | Intel Motherboard
How install new bios
After updated your bios, did you check the boot sequence?
it might have been changed. Go in to the bios again and check so the boot setting is pointed that your pc starts from your HDD.
If you trying to reinstall the OS you should change tye boot to start from you cd-drive.
Good luck to you
If you find my answer helpfull, dont forget to vote
Gigabyte GA-7VKML Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
