Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Bent I need to recover the info on this Cruzer Micro USB and I'm pretty good with a soldering iron. I need a diagram to solder a cut USB extension cord to the damaged flash drive. There's alot of Fire Department Grant related items needed from the drive. Can You Help? Capt. Moulder
    Scholar:
  • 172 Answers
I have a solution to your problem.kindly send me photograph of the cut ends opened up and the end of the microusb showing the soldering points. i shall then guide you well . also if you have a continuity tester and a voltmeter then things would be easy.
you have to identify four points two data and two supply
ground is always black and red is always negative. the rest two are data. which are usually white in color
Posted on Jun 23, 2008
How do I re-solder the micro usb power receiver back on to my cousins digital2 7" tablet?
This is a pretty delicate solder but if you are comfortable then all you need is a soldering iron and some solder with a flux core. Warm up the iron until it can melt the solder and melt the two together. I do have to say that it is not that you can't do it but I have 18 years of soldering experience in telling you this wont be an easy one.
Feb 15, 2015 | Digital2 Tablets & eReaders
Hi I got a belkin CoolSpot Anywhere Ultra cooling pad for my laptop but it doesn't work now because the usb is bent. How do I fix this?
Just cut the end off that is bent. Locate a cheap USB extension cord (6 inch is all you need) Cut the 6 inch cord in half and strip the insulation back 1/8 to 1/4 inch. Do the same application with the end attached to the cooling device. With a soldering iron (25 Watt pencil iron) solder the like ends of the exposed wires together. If you have Shrinkable insulation that is a good cover and simple to use. If not use a good insulation tape to cover the soldered wires. That is it!
Mar 13, 2014 | Belkin LAPTOP COOLING PLATFORM * WITH FAN...
Hello, My USB device got bent. I carfully bent it back and it looks okay but my computer said it malfunctioned. Is there any way to get my info off of it?
Probably just broke the solder join on the USB plug. I have used a fine tipped soldering iron, and re-sweated the join again, and you will probably fix it.
Feb 15, 2010 | Verbatim VER95327 USB Hard Drive
My flash drive bent and I think some of the inside wiring is messed up. Is there somewhere I can take it to get this fixed or someway to recover the files I have on it?
these flash drives are very easy to damage, You have to understand that its very risky to solder on the board because of static will destroy the information on the chip. If you want to get the information recovered and the files are not able to be replaced by downloading you are talking alot of $ for this recovery cost. you can contact this company who is sandisk certified to recover sandisk products.
Jan 19, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Aug 06, 2009 | Sony MDR-V700DJ Professional Headphones
Sony Flash memory card - 2 GB Memory Stick PRO My memory stick board was bent and now it does not detect. Can the flash memory chip be removed and then soldered on to another working Sony memory stick? if...
very difficult to retrive mem. cannot be soldered due to the traces are microscopic and an iron would go through multiple traces. try putting in cpu rather than cam to try and save to hd. good luck hope this helps.
Jun 04, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a 1 GB flash drive that is physically broken and my laptop won't recognize it. The pin got bent and was partially out of the case.
relax , as long as your flash drive is not smashed with a hammer
we can get it back up and running , your notebook on the other hand may need a little technical lovin'
if you broke a pin in the USB port , thats gonna take some serious work , if the notbook is under warrenty use the warrenty
if the notebook is passed it's warrenty , then you CAN do the job yourself , you'll need to remove a USB port from a junk motherboard or better , and use that to replace the broken pins
that does involved some soldering with a solder gun or pen
which might cost you about 10 to 20 dollars as of 2008
Good luck and may the nforce2 be with you , always.
Aug 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The USB connector broke!
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
Jan 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive was bent
You could try attaching another USB terminal/plug (soldering it), but then if you lost your files, you could try using Professional Data Recovery services... but that's expensive.
Dec 14, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
79 people viewed this question
Top SanDisk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
CiNi
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
