Question about Sharp AL-1217 Copier
Scanner Position Error
Greetings!
My sharp AL-1217 greets me with a flashing "L1" error - should be scanner position error. The scanner is not locked, the unit moves from right to left when I put it manually in a different position on startup - so it seems to know that the unit is not in starting position. It runs back to the left, moves for four to five centimeters - and shows the error.
Any idea what it could be exactly?
  • 79 Answers
Hi i think this is carrage home position sensor problem. u check and clean the sensor and try it back. or any forign meterial blocking in carrage way.. pls check that also.. all the best..
Posted on Aug 18, 2008
2 Suggested Answers
jon_than21
  • 30 Answers
SOURCE: My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Posted on Jul 28, 2008
Old model AL-1217 photocopier giving error reading of L? Any thoughts, tried everything! Thanks
L1 mean scanner is not goes home position,
Solve: Clean all surface then solve your problem
Feb 06, 2010 | Sharp AL-1217 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Sharp al 1661 cs ..it shows System error(L1-00)
When your copier scanner is locked then show L1
Solve :Unlock position
clean all surface in scanner area
clean scanner sensor
Nov 05, 2009 | Sharp AL-1661CS All-In-One Laser Printer
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Jul 28, 2008 | Sharp AL-1217 Copier
Scanner bar won't move
According to another source, the L1 error means "Scanner position error". Hope you find a solution, and not an expensive one.
May 16, 2006 | Sharp AL-1540CS All-In-One Laser Printer
211 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
