Back to:
Tags:
Toshiba 42H81 42 in. Rear Projection Television
Toshiba 40who8b convergeance problem (by 2 users)
posted by harri1234 on Jun 23, 2008
picture bows up from bottom coloures out of line
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by mketre, posted on Jul 10, 2008
I had the exact same problem one year ago, blue out ovf convergeance. I brought the unit to a repair shop, they replaced 2 ICs (not sure if they are "t" or not) and the set worked great for exactly one year ($350 parts and labor). Today the same problem happened. Should I repair it again or am I thrownig money down the drain. The set is 7 years old.
Matt
Best Solution
FixYa! (100)
BIG IRISH
Rank:Wiz Wiz
Rating: 85%, 239 votes
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Rating Locked! (?) harri1234 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toshiba 40who8b convergeance problem:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
Toshiba 42H81 42 in. Rear Projection...
I am having a problem manually converging my tv. the touch...
Had Convergence problem, replaced the STK 392-110's on my...
I have lost the users manual and cannot find where to get...
i need to know the number/letter locations of the...
I don't how this happened but the question writen under my...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
