Question about Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart LX 18 problem
I have a Hobart LX18 rinser and the machine seems to keep adding trickles of water via a supply line midway up the machine. It tends to fill overnight and spill on the floor. Any suggestions. We clean the 4 nodules daily and do not seem to get an error code.
    Scholar:
  • 68 Answers
You are having a problem with the fill valve. If the unit fills AT ALL, with the power off, the fill valve is the issue.
It is a gold color valve behind the front kick panel. It has a large castle-like cap. Sometimes debris is the cause of your failure. (50/50). Turn off the water, and just take it apart slowly and pay attention to the plunger and spring. Take out the diaphram and screen, and clean it. There should be just one small hole in the diaphram. If cleaning doesn't help, you need to buy a rebuild kit. If you get the "ML" off the data plate, I can get you the kit P/N.
good luck
Posted on Jun 24, 2008
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Have a hobart LX18 it will not fill can you help
hello,
A Dishwasher is a high quality product that focuses on energy efficiency. In addition to saving money on electrical use over other machines, they use less water than the average dishwasher. When your Dishwasher is not filling with water properly, before you call for a service appointment, check the components yourself.
    instruction
  1. Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
    If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
    There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
thanks.
Oct 23, 2010 | Hobart Dishwashers
Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
Nov 21, 2009 | Hobart Dishwashers
Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Jun 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
LX-18 error code E4 what is the problem? Replaced motor runs great.
the water does not seem to be pumping to wash the dishes....could something be plugged? I can hear the pump and it pumps the water out at the end...
Mar 06, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart lx18
$0. Clean the probes. Two in back right corner. Two under the front screen. Use a green scrubby.
If the problem persists, check where the water comes into the machine. There is a screen on the hose that clogs up and starves the machine for water.
Apr 12, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart 24 in. LXIC-5 Built-in Dishwasher Logo
321 people viewed this question
Top Hobart Dishwashers Experts
Ricardo311
Level 1 Expert
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
