Question about LG Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
    President:
  • 1,140 Answers
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Posted on Nov 25, 2010
  • 4 more comments
  • peter_pd Nov 25, 2010
    It's the Lg M2280D LED TV
  • DILLIGAF
    DILLIGAF Nov 25, 2010
    Your TV is too new for any current Sky remote to have a specific code programmed. The LG brand code is 0065. If this doesn't work, you can try all of the codes listed in my next message below. If none of them work then, unfortunately, your Sky remote cannot be used to operate your TV. You will need to use the remote supplied with your TV to operate power and volume functions until such time as Sky release and updated remote. BElectric
  • DILLIGAF
    LG Codes:
    065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
  • DILLIGAF
    Please copy and paste the link below into your browser if you need information on programming 3 and/or 4-digit codes into your remote. If you have no sucess and you still want to use one remote, your other option is to find a universal remote that will operate both your TV and Sky box. Regards. BElectric
  • DILLIGAF
    http://www.skyuser.co.uk/tutorials/sky_r...
    None of the codes work but thanks for the information.
2 Suggested Answers
SOURCE:
Emsy32
  • 3 Answers
SOURCE: Sky remote handset will not operate mute. volume etc.
Go to interactive
Select Number 5
Then select the remote option (5) You will then get a list of tv models with codes, follow the directions on screeen
Posted on Jan 06, 2008
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
Feb 09, 2013 | Televison & Video
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Televison & Video
My sky remote wont operate the sound of my grundig 37fhd1080p tv is there a code that can help this
The code you have to input is 527. Press and hold select and red on the sky remote until the red light flashes twice, then input 527 and press select. Now try the volume control on the sky remote. Should work. Hope this helps.
Jan 12, 2011 | Grundig GU22DVDPX 22 in. LCD TV
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
Im trying to get my sky controls volume to work on my sharp tv but need a code
On the Sky remote Press the Following.
TV,
RED + SELECT (blinks twice)
TV,
0093
try the VOLUME if this does not work. Press TV then VOLUME again repeat until Volume works.
Once the volume works press SELECT on the remote to store.
Hope this helps
Little Dish Fitter
Aug 26, 2009 | Sharp Televison & Video
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Televison & Video
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Oct 18, 2008 | Televison & Video
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Televison & Video Logo
280 people viewed this question
RONALD CARTER JR
