Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Device firmware i tried to downgrade my zunes firmware and i deleted the firmware and connected to the comp and opened the software to download new one but it said zune firmware is up to date
  • 8,596 Answers
Http://www.zune.net/en-us/support/usersguide/default.htm
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
It keep telling me that i need to restore the zune device firmware
The "firmware" is specialized software that gets downloaded to the ZUNE.
Then, when you turn the ZUNE on, it runs that software, to control the device,
i.e., to respond to the buttons that you push, and to retrieve files from the "library" stored on it.
If that firmware gets corrupted, you must download a copy of the firmware from the ZUNE web-site, and then run the ZUNE software on your computer to download the firmware from your computer to your ZUNE.
Nov 30, 2010 | Computers & Internet
Zune won't sync and now some songs will not play all they way through
Go for software update from the zune website it will help you.
Also ensure that the settings are not changed .
Sep 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
PC will not detect my zune.
Hera re some ideas: http://www.devicedriverfinder.com/blog/device-errors/how-to-fix-zune-device-errors
Hope it helps solve your problem in case it still exists.
Jules
May 27, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Error code c00d124d appears on my zune while sync
You may have to attempt a Hard Reset if this issue is persistant.
This will erase everything on your device, as a warning please be certian you have backup copies or this is a last resort.
Here is the original post:
WARNING: A hard reset will delete everything on your Zune.
  1. Press and hold the back button
  2. Press and hold up until it reboots
  3. Depending on which Zune you have, immediately do one of the following:
    1. If you have a Zune 4 GB, Zune 8BG, or Zune 80GB, immediately press and hold the Back button Back at the same time as you press the right side of the Zune pad and the Play/Pause button. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    2. If you have a Zune 30GB, immediately press and hold the Back button Back at the same time that you press the right side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    Good luck, Let us know
Apr 14, 2009 | Computers & Internet
Windows 7 (64 bit) build 7000 and zune problem
i had the same problem at first with my 3rd generation zune. first you have to open up the zune software folder then right click the short cut and click run as administrator then it will detect the device and everything will work. good luck
Mar 19, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Broken zune
i get the same exact problem what i do is restart my computer and plug my zune into a diffrent usb port(i have 4...2 in the front and 2 in the back) and my back ones work fine try that and let me know if it works
good luck
~Temp
Aug 28, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune Storage
Through the software in the device options you can delete everything on your zune (same as a reformat on your computer harddrive) this should solve your problem for the most part... If not there is a keycode that will ERASE EVERYTHING including firmware so you can start fresh.. Just try the software method and see how it goes.
Dec 31, 2007 | Microsoft Zune JS8-00001 Digital Media...
Hey!! I just fixed mine! I had recently installed drivers for a PS3 controller, and for some reason those were conflicting with the Zune.
To fix it, I went to add/remove programs, and then removed the libusb program, that fixed it instantly! Good luck!
Dec 04, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
136 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Ap12
Ap12
Will Mishler
Will Mishler
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
