Question about Cyberhome CH-DVD 300 DVD Player
Bad disc Hi! I have a DVD 300 bought about 2.5 years ago and watched about 10 movies, (don't used it much) either rented in the USA or bought in Belgium. I live in the US but am from Belgium. Now after "loading" for the longest time it says "bad disc" even with brand new one or even with a cleaning disc!! Thank you so much for your help. carissas@gate.net
  • gebrew Jun 27, 2008
    It suddenly says Bad Disc on any disk. I played them ok on another player
  • carissas Jul 21, 2008
    Thanks for the advice. Followed your instructions but it didn't work.
    Thanks anyhow.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Try cleaning the lens yourself. Before taking drastic measures as replacing stuff, try cleaning the lens on the DVD/CD Drive. You will need to open the unit and also open the DVD/CD case. Make sure you do this while the unit is unplugged from a power source. Locate the lens that reads a dvd/cd. Now get a cotton swab and moisten it with isopropyl alcohol (rubbing alcohol) and gently rub the lens clean...use the other dry end of the cotton swab to rub it as well. Try not to use too much alcohol on the swab and not too much force when rubbing. Let it dry for a minute or 2 and screw the unit back into 1 piece. Moisture, cigarette smoke, insence smoke, and dust can cause a barrier between the DVD/CD and the reading lens and by doing this you will either fix the unit or know that it is a problem that will need replacing. Good luck!e lens yourself manually
Posted on Jun 25, 2008
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
Wont play disc back that it recorded.
I get loads of the same question you ask every day, the DVD disks do sadly fail, out of a pack of 10 you can say that 2 will not write or play back, this is still the reason most pro movie makers like myself will only use movie tape today like the Hi 8 mm sort.
Also beware as we have found that lots of DVD disks we have made over 9 years ago no longer will work, so never feel your precious movies are pernament with this new mode of recordings.
May 30, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
I bought a Toshiba DVR about 3 years ago and ever sence I bought it, it has never recorded anything on any DVD+R OR DVD+RW that i could find and it will not even play already recorded dvd's or play half of...
Don't understand why you didn't take it back and ask for your money back 3 years ago? I suggest you go to an legal advice center and see if you can still do something about it.
It sounds like the lazer or lens could be faulty. However it could be just a bad soldering joint.
Jun 20, 2009 | Toshiba DR4 DVD Recorder
Always says bad disc
Try to clean the DVD lens using a lens cleaner.
Feb 16, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Wrong region
hi!your english is good!!
please try this:hope it helps!
dvp720sa
dvd player on
open tray
(no disk inside)
1. Turn on the player.
2. Open the tray.
3. Press the following sequence on the remote: 9-9-9-9-0
4. The number 0 will appear on the lower left side of your screen.
5. Your player is now region free! Put in a DVD and enjoy!
NOTE: The 0 in the sequence above represents the region code. 0 = region free. If you want to change your player to just a specific region code, replace the 0 with the region number you want.
Nov 20, 2008 | Philips DVP 720SA DVD Player
DVD player won't work for Panasonic SC-HT680
la tarjeta de elcctricidad se me quemo y no encuentro respuesto
Oct 11, 2008 | Panasonic SC-HT680 System
-bad disc reports
The problem with using rental discs is that they are dirty. Buy a dvd player cleaning disc and follow the instructions. These discs help to realign the laser. If this does not help try cleaning the disc with a disc cleaner. Also depending on how new the dvd is there have been a lot of discs manufactured outside of the US that have been bad. It may not be your machine but the discs. I personally went through 6 of the same movie before i gave up and rented something else that worked perfectly fine. Hope this helps you watch.
Sep 11, 2008 | Televison & Video
Can't read the disc !!
I replayced dvd cd-rom myself it's very simple repair and it cost me $20.00 for new dvd rom. Don't buy CD-RW but just simple black dvd-rom.
I hope this will get you going again.
Jan 28, 2008 | Bose (321GS) System
'Enter' button not working with DVD's
Hi - had the same thing. Hardware reset fixed the problem. Hold the power button for more than 10 seconds, and everything goes back to normal. And no, it's not in the manuals or on the toshiba web site.
Jan 02, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Cyberhome CH-DVD 300 DVD Player Logo
96 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
