Question about IBM E54 15" CRT Monitor
Monitor broblem it is ibm crt monitor that the picture is blinking
    Champion:
  • 214 Answers
Hi, goto desktop properties, settings,advanced, monitor tab. There u reduce the screen refresh rate.
thank you
Posted on Jun 23, 2008
Lines appearing on minitor
If the lines are off color such as green, it is a picture tube issue, if lines are white, picture tube is been over driven, suggest a professional.
Mar 11, 2012 | IBM E74 17" CRT Monitor
My Ibm monitor light blinks continously but nothing on screen and the is a clicking sound continously
There is a short within the HT section and this can be possible with the failure of the flyback transformer or the driver transisitor.
So if you are equipped please open the back panel and check for shorting on the driver, also when powered this can heat up which confirms that the flyback is shorted.
replace with the same type.
Oct 01, 2011 | IBM E74 17" CRT Monitor
Greetings! We are using IBM E74 model CRT Monitor, The monitor was dead, No power, no display How can i rectify that? please give me the instruction
Jun 11, 2011 | IBM E74 17" CRT Monitor
Ibm e74 17 crt monitor screen is black with the indicator light flashing green.
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....monitor LED just blinks & no display .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( very much compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.... SOME TIMES ALONG WITH EHT....A TRANSISTOR ( BIG IN SIZE & FIXED NEAR EHT) ALSO GETS DEFFECTIVE...........SO IT SHOULD BE COMPULSORYLY CHECKED BEFORE REPLACING EHT
Jan 24, 2011 | IBM E74 17" CRT Monitor
Lcd in by on by on blinking for vga
power cable or data cable connection loose please tight or after removing the connection do it again tightly
Sep 08, 2010 | IBM E74 17" CRT Monitor
BLINKING OF SCREEN
check for Dry Soulders & FBT....
Jan 06, 2009 | SAMTRON 55V 15" CRT Monitor
My monitor led keeps blinking,but there's no display
this may be bcoz of probly fauly RAM......... remove ram & use rubber & srub the RAM pin & install again chk this if this will help you...................Sameeraryan
Jan 02, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
IBM E54 CRT Monitor - Exceeds the Display Width
1. first replaced the TIP 122 fet. back side of lot.
2. change the 424j / 1600v pf.
3. IRF 630 ( after power output section )
Nov 17, 2008 | IBM E54 15" CRT Monitor
Monitor signal cable troubleshooting
hi, there is some loose contact in the connection. Take out the cable end from the VGA socket and check the pins inside the socket for any bend inside the socket. Reconnect it, tight the connector with the socket bolts. If not solved, try for any loose solder or wire breake.
Thank you
Jun 23, 2008 | IBM E74 17" CRT Monitor
IBM E54 15" CRT Monitor Logo
100 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
