Question about Roper RAX4232KQ Top Load Washer
Makes a hard banging noise when the washer is draining and spinning
I know what the banging noise is when the load is unbalanced, this noise sounds like gears or bearings.Any tips of what to look for and how to fix it would be helpful.
Thanks
T.H.
    Problem Solver:
  • 12 Answers
Check the springs, and make sure the water ring still has water in it.
Posted on Feb 07, 2009
Banging noise during spin?
uneven load on washing
more likely drum bearing broken hope this helps
Mar 14, 2015 | Washing Machines
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
2003 ford sport trac front grinding noise from drivers side when sharp left turn
go to the magicmechanic website and send him this--hes the best there is and will rply
Jan 19, 2015 | 2003 Ford Explorer Sport Trac
I'm getting a "UL" (Unbalanced Load) code all the time, it is level and always happens with 11 minutes left in the cycle. What is the problem? Is the tub bearings out? Why is grease leaking?
This definitely sounds like a new bearing is required. It is not unusual to see grease leaking of the bearing has been damaged or is worn out. If it is banging, making loud noises or shaking the machine violently then the bearing is usually the problem
Sep 07, 2012 | Whirlpool Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore model # 20642 991 leaks water when it spins (mostly with large loads) and the barrel inside seems to be loose or something because it bangs hard against the inside - sounds like the whole...
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub. The banging noise is due to being unbalanced. You may need to replace the balance ring on the top of the drum inside the washer. Watch this Video to see if this is how your machine is acting.
Nov 26, 2010 | Kenmore Washing Machines
Front Loader Model #FWT449G5S00 banging on spin cycle. One bottem shock snapped replaced with new shock kit (twice) still bangs. At first I thought bang ( out of balance problem) was because of the broken...
The bearings on the drum may be going bad or the counter weight may be broken off or missing or heavy unbalanced loads. Reach inside and try lifting up on the interior drum. If it moves up and down or you feel any popping I would say the bearings are going bad. They usually make a lot more noise on the spin cycle also. Similar to an airplane taking off.
Hope this helps.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
Roper RAX4232KQ Top Load Washer Logo
251 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
