Question about Zebra TLP 2844-Z Thermal Label Printer
Will not print on all four lables, and does not print in the same place each time.
I have a printer that is having several problems. It should print the same information accross on 4 small lables. It does not print at all unless we increase the darkness to 30. Once we increase the darkness to 30 it prints only on the two at teh right of center. The last thing is it is not alinged. It will not print the label in the same place. It takes several times for it to print in the proper location.
  • 53 Answers
For starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Posted on Sep 03, 2008
If i print the barcode he print and leave on barcode plane when print more
Posted on Aug 10, 2009
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Feeding-problems
you need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
May 14, 2010 | Zebra TLP 3844-Z Thermal Label Printer
When Printing labels the printer starts to soon and bottom lables are cut in half?
After you press print the window pops up with printing preferences, select preferences and tell the printer you are printing labels, it will allow more time for the label to reach the start position and start at the right place on the label sheet.
Feb 01, 2010 | HP PSC 1410 All-In-One InkJet Printer
LPT Zebra UPS Thermal 2844 Printer Printing Slowly
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever settings where mucking it up.
If this doesn't fix you, it is an issue between the software you are using (? what kind is it?) and the printer driver.
Aug 05, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Dec 19, 2008 | Zebra 105SL Thermal Label Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Physical alignment of lable holder lost
pleasesir check its lock and screws for open it but take care
Sep 21, 2007 | SATO CX400 Thermal Label Printer
Printer prints blank pages
I have the same problem, I am told the print head is clogged. there is several products on the market for cleaning them, but none of them seem to work for everyone. including mine.
I found a website selling new print heads for it, but its the same price as the printer was.
I'm throwing it out and buying a HP. which I should have in the first place.
Jan 21, 2007 | Epson Stylus CX6400 All-In-One InkJet...
Zebra TLP 2844-Z Thermal Label Printer Logo
444 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
