Question about Lakewood MC-42 Fan
MC42 Replacement Fan Motor Part Number
Having trouble finding a replacement motor for the MC42 fan. Not sure of rotation . Would like to be able to cross it over to a dayton motor if possible. Thanks for your help in this matter.
George Schmidt
Assisitant Chief Operator
American National Insurance Co.
E-mail: assistchief @comcast.net
  • 2 more comments
  • Anonymous Jun 26, 2008
    we need cost and delivery on a replacement motorfor resale MC42 - 1HP
    thanks gilbert
    c-d electric motor sales & service
    361-888-4133
  • Curley Wolf Oct 02, 2008
    Need replacement electric motor for fan Model MC-47-LG. It is a 1/2 hp, 120 V, 60 Hz, 5.5 Am, Class A, Thermally protectd & Capacitor, 10MFD 450 VAC. Would like source and part number.
  • burzerko
    burzerko May 11, 2010
    ok off the motor tag I will need the following info:
    voltage
    amperage
    frame type:
    should say cw or ccw somewhere on the motor as well.
  • KENNETH
    KENNETH Jul 29, 2014
    ONLY NEED CAPATOR 10/450 MOTOR RUN GREAT
    Champion:
  • 254 Answers
Ok If you take the info I asked for grainger is able to cross refrence it for you in case they dont have the particular model#
Thanks hope this helps Ya
Posted on Jul 05, 2008
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
The fan on the inside ac unit wont come on is there a reset button
One of the common problems in air conditioners is fan motor bearings going bad and the fan motor shaft is locked up stalling the motor or preventing rotation. Another cause of fan motors not running could be the motor start capacitor. The capacitor is needed to give the motor a jump start to get it rotating. If you can get access to the fan squirrel cage and can spin the fan ok, the motor bearings are then good. Most likely the problem then is a bad motor start capacitor that can be replaced. In very rare cases the motor winding itself could be bad and the fan motor will need replacement. regards, Dennis
Feb 27, 2015 | Heating & Cooling
How do I find a fan or fan motor for an Emailair air conditioner 110RC Room
you have to find an appliance parts house you can chesk online to you will need serial no. model number. rotation of the motor amps and hp. the best i to take the motor with you
Jul 20, 2014 | Heating & Cooling
I just replaced the motor to the condenser fan, after I put the blade back on, and finally got everything moved and screwed back down I am wondering if I put the blade on so the air flow is going in t
If you replaced the fan motor with the correct rotation replacement motor the fan should be blowing in the right direction or did I misunderstand what you are trying to explain? Sea Breeze If the part number is=> WR60X187 the motor should be turning clockwise rotation while looking at the motor from the rear. Thanks JT
Jan 26, 2013 | GE Monogram Side by Side Refrigerator
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Exahaust fan not working
The best thing to do is buy the replacement motor. It is usually a pretty simple thing to change out and it sure beats having to take down the whole thing. Here is an article on finding the right motor. http://nutoneproducts.blogspot.com/2009/05/nutone-bath-fan-motor-replacement.html
Jul 12, 2009 | Broan-NuTone N-667RN Combination Light Fan...
Replacement motor
your blower fan screws onto the end shat of the motor. Now the direction? It could be reverse threads. Since you are changing out the motor stick a screw driver in the old motor to lock it up and try righty-lefty to loosen your fan. don't damage the fan with tools. Go here and see if your fan is shown www.repairclinic.com
Mar 19, 2009 | Whirlpool Dryers
Noisy Evaporator Fan on a Kenmore model 596.76579600 refrigerator
The replacement evaporator fan for your model is a part number 12002744
Mar 15, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Lasko E20739 Fan
It sounds like the electronic controls have put the fan into "breeze mode". The fan turns slowly then is supposed to surge back to high. Some people love this feature for some reason...
Disable breeze mode via your remote (its the button with the stacked ~'s).
A bad motor wouldn't rotate at all. The only other problem might be the motor's running capacitor. If you can start the fan in either direction (give it a hand spin in the opposite direction of rotation) you have a bad capacitor...and you can find a replacement anywhere (Radio Shack).
Aug 03, 2008 | Lasko 2530 Elite WindTower Fan
Lakewood MC-42 Fan Logo
4,103 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
