Question about Kodak EasyShare C743 Digital Camera
C743 digital Insert two new duracell batteries, short term use and have to replace with new batteries. Also, if batteries kept in camera, camera does not work. Help
  • 3 Answers
A Kodak tech told me to use only rechargeable batteries as regular dry cells do not have enough power and will go dead at the most inconvient time.
Posted on Aug 09, 2008
Which battery should we use duracell non rechargable or chargable
Any battery but when you are not using it take battery's out because
1. They are being drained when in whether you are using it or not.
2, If you leave them in long term they start to corrode and then mess up the connections where battery's fit.
Apr 06, 2016 | Duracell Cameras
Satellit 800-batt blinks w/new Duracell alkaline batteries.
Have you checked the voltage on the new batteries.??? Some batteries, even if they are new... have a short shelf life, if they aren't used. You will need a volt meter or battery tester...if you dont have either, take the batteries to a Radio Shack or even a Auto store and ask them to check it for you.
Oct 20, 2014 | Cameras
BATTERY LIFE REALLY SHORT
If your camera (and the battery) is over three years old, buy a new battery.They tend to loose life after 3 yrs.)
Jun 18, 2010 | Kodak EasyShare C743 Digital Camera
EasyShare C743 Digital Camera: I just bought a new 8 gig Kingston SD card for my ...
The C743 is only good to 2 GB other models of Kodak can use the larger cards but not the c743
May 17, 2010 | Kodak EasyShare C743 Digital Camera
Installed new battey but camera does not turn on
check the brand of battery to be sure it is compatable with the kodak. I found some batteries have a short positive electrode that will not contact the metal plate on cameras battery door. Cheap batteries will not even turn these cameras on.
May 12, 2010 | Kodak EasyShare C743 Digital Camera
Hello i put in new batteries into my camera today and it wont turn on....help! and yes i put the batteries in
Are you using the AA alkaline battery? If yes try to reverse the orientation of the battery instead of positive negative make it negative positive
Now if your using new rechargeable make sure thats the AA Ni-MH this Ni-MH is highly recommended for your camera C743
Nov 11, 2009 | Kodak EasyShare C743 Digital Camera
Camera will not turn on
It may help to remove the batteries for a few minutes or clean the contacts. Repair of cameras is more expensive than replacement, but it may help to clean and charge the batteries as described below.A friend asked me to clean and charge her new 2000mAh Duracell batteries as described in the next link. Those batteries are still going strong after four months of normal use and have not been recharged.Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. http://www.google.com/base/a/4210404/D13...Also, digital cameras reset to original settings if batteries are removed for one minute. Time varies with function/camera. Check display/setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged/cleaned batteries and restart camera. The ultimate non-physical repair for software-using devices is reset by removing power ... VCR/DVD players one month.Most NiMH rechargeable batteries lose charge and should be recharged when not used after two weeks, but Duracell and RayOVac new formula 2000mAh NiMH batteries hold charge one year when not used. Also, 2000mAh batteries seem to have a longer life. Did not like these batteries at first, but have 12 over five years old and all are still as good as new. Higher mAh batteries (about one year old) still work well in flashlights, but won't start my camera.CAUTION Do not overcharge! Batteries can be damaged. Use an automatic two or more hour Energizer Compact smart charger with temperature monitor, trickle charge technology, and safety timer ($9.76) at Walmart. Use pre-charged 2000mAh Duracell ($12.97) or RayOVac ($5.97) batteries (both hold charge one year) and a full cycle charge. To preserve battery charge, use the viewfinder.If batteries are removed more than a few hours, the date/time setting and other set-up information will be lost. If the camera is being stored for a long time, the batteries should be removed and stored properly.Carry and dispose of batteries in baggies, blister packs, or other containers to protect ends from short circuit. Batteries explode when short circuited. NiMH batteries are environmentally friendly and may be discarded with trash.The next link is about prolonging the life of lithium-based batteries which last from two to three years, but are very expensive. A Sony series G rechargeable 960mAh lithium-ion battery is $49.88 at Walmart.http://www.batteryuniversity.com/parttwo... ...Camera reports batteries low, but is it low charge or bad electrical contacts? Overcharging can ruin good batteries! The secret to making digital cameras work better is having good electrical contacts between batteries and camera.Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but camera will indicate "low" if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out. NiMH batteries should be recharged when camera reports batteries low. Old batteries can discharge over night, but may provide normal service immediately after being charged. Battery pairs no longer usable in cameras may work well in flashlights. Do not drop batteries or allow voltage below one volt.CAUTION To prevent memory card corruption, keep batteries charged, format in camera, and don't delete or fill card completely. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select, then click Stop and OK.Never touch battery ends or camera electrical contacts. Oil from fingers will contaminate contacts. Use batteries in matched pairs of same brand and rating. Do not mix old and new batteries. New will only do as well as old.Click source link for other camera tips and complete instructions on cleaning camera and battery electrical contacts.
Apr 10, 2009 | Kodak EasyShare C743 Digital Camera
Kodak C743 Battery Discharging When Switched Off
I would suggest, if under warranty, to take it back to the store or contack kodak for a replacement. Otherwise, start shopping for a new one. There are a ton of great digicameras available for the same if not cheaper than this one.
Apr 25, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
100 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
