Philips DVD recorder with Hard Drive
Where do I get the info on my model.
DVDR3570H.
I need to delete recordings on the hard drive, but cannot find that in the manual or on the menu's.
I also have interference, so am trying to improve the signal output to the TV - somehow, but I don't know how.
Any suggestions ?
Can I tune in the TV to an analogue output from the DVD , otherwise I always have to switch my Hi-Fi on to be able to watch anything, & the quality is not much better on AV channel on the TV.
Thankyou.
Tibor.
South Africa.
  • 1153 Answers
SOURCE: wharfdale DVDRHD400 dvd recorder with 80gb hard drive
Sounds like if you are getting the right Video and not audio then the audio are hooked in wrong. Unless you are on SAP (Second audio program) in this case take it off of Sap. If you are getting the sound that you are looking at once you change channels to view another program, then it should be easy. Just change audio jacks back to AV1, 2, 3 etc depending on which one you are using. Hope this helps!
Posted on Dec 03, 2007
BobbyR1234
  • 173 Answers
SOURCE: No sound when watching TV
I would check all cables to make sure they are connected properly and secure, also check the cables for any defects ie bent pins, frays in wiring, etc. and check all connectors on the front or back of your tv (which ever way you have it hooked up) to make sure they are not loose or damaged first. 2. I know you can connect your dvd properly, but I have to suggest it anyway, go back through the manual and make sure all settings are properly set.
3. You may need to update your firmware, which you can find instructions in pdf at this link it will be the 6th link down in pdf. I tried finding your device on the manufacturer's website, but you need the model number, I will include that link as well. Since it only 6 months old, it should still be under warranty so I would check into that as most usually have 1 year warranty. If all else fails, it might be something internal with the dvd recorder and you will have to get another one or take yours to a repair shop, but if you do take it to a repair shop make sure it is one that is reputable and trust worthy. I hope this helps you out and I am sorry I could not be more specific on the problem.
Posted on Jun 02, 2008
SOURCE: I have a DVD recorder
Tuner fault
Posted on Jul 21, 2008
SOURCE: how do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: Philips DVDR3570
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Posted on Dec 06, 2009
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
I delete file`s that i still needed
you can't recover files that may have been permanently deleted, unless the device has a Recycle Bin like a desktop computer.However, there are certain devices that come with a .trashes folder where deleted files are stored. yuo can recover them through that.
Jun 21, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
DVDR3570h is stuck in standby, cannot turn on
Mar 15, 2009 | Philips DVDR3576H DVD Recorder
Philips DVDR3570
Nov 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD Recorder
double check the firmware from philips website, but most likely that hard drive has an internal problem
Aug 24, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR3570H HDD DVD player Recorder - done basic set up last night but the start up search for analogue channels returned 0 - speant 2 hours re arranging plugs & it still wouldn't locate them? do...
The DVDR3570H will only find analogue channels if you have a TV aerial connected to it.
If you only have a satellite or cable box, then you can still use the recorder, but you will have to use the AV inputs on the recorder. In this case you will only be able to record the satellite or cable channel you are watching.
May 01, 2008 | Televison & Video
Philips DVDR3570H/05 constantly looping on startup
Apr 09, 2008 | Televison & Video
Hard drive shows full even after erasing 120 hours.
You should empty the recycled bin in the system and delete all temporary files on it.
Jan 10, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
