Phillips Plasma 42" TV
Blinking red light only,I unplugged it for acouple of min.and started working for a few days and it is out again,with the blinking red light on again.
  • machine4550 Nov 27, 2008
    red light just blinking, normally light is greem and now it blinks red and wont turn on
  • Anonymous Jan 05, 2009
    Same exact thing happened to me. It was 2 months after warranty when it died and I don't have the money to replace so it has been sitting on the wall unusable for 6 months!
    Problem Solver:
  • 5 Answers
There are two capacitors that need to be replaced. just did it today
Posted on Feb 05, 2010
    Sergeant:
    Champion:
  • 231 Answers
What model do you have?
Posted on Jun 23, 2008
Panasonic 42 tcp42x3 plasma tv turns off after 5 minutes solid red ligh no blinking will turn back on if I unplug and plug back in but off in 5 mins again
The fact if unplugged etc and tries to function means a micro related problem---if unplugging all units for a while does not change this then suspect a power supply or main board (controls all functions).
Oct 15, 2012 | Panasonic 42 TCP42X3 42 Plasma TV
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Oven will not bake but everything else works fine
What is the red light blinking? Count the blinks before it pauses and post back here. It'll give me and everyone else a starting point.
Jan 21, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
It is most likely a power supply failure and if there had been no signs of problems in the video display, it is probably the main power supply rather than one dedicated to the plasma display itself.
You might leave it unplugged overnight to give any stored charge inside the unit a chance to bleed off, the remove the back panel.
The primary supply is normally on a separate board and is characterized by having mostly larger components, including one or more transformers with black ferrite cores. The main supply will be associated closer to the AC input while the high voltage supply which may or may not be separate is not.
If you can locate the board with some confidence, check it visually for any signs of heat such as discoloration of board or components. If it seems OK it may be a candidate for exchange or repair by Philips.
I wouldn't advise removing and sending it before you talk to Philips to see if this is a familiar problem to them.
Dec 16, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Phillips 42" plasma42pf5321d-35
Replace the small signal board 313926727671.
Oct 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
2 year old Phillips 42" Plasma TV won't turn on
Hi I had exactly the same problem, bought the above parts off ebay. The above solution worked and tv back to normal. the soldering is a bit tricky and there is a lot of screws holding the back on!
Sep 13, 2007 | Televison & Video
TV Won't Turn On
My phillips 42" is the same way. Just started popping up the settings menu the other day and wouldn't stop popping up until I downloaded the software upgrade from the Phillips web site. But now, two days later it won't do anything but give that same annoying red blinking light. The customer service says to take it to an authorized repair center. sounds like they have a ton of these calls everyday. The solution is to buy it from Costco, and make sure you return it and get a new one before their return policy expires.
Apr 22, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
329 people viewed this question
Top Televison & Video Experts
Electro Med Services...
