Question about Belkin Wireless-N Wireless Router with 4-Port Switch
Belkin N1 routers
I wish to connect two belkin N1 routers to extend my network. One will be connect to the cable modem. How do I configure this particluar topology?
    Sergeant:
  • 287 Answers
First off you need to change the defaault IP of one of the routers so that you can access them both via the web based interface. The default is 192.168.2.1
Do you plan linking them via cable or wireless?
Posted on Jul 06, 2008
Belkin n300db range extender setup problems
we will give you full guidance how to install Netgear N300 wireless.
There are following steps
Step1: Unplug the power to turn off your modem
Step2: Connect one end of the yellow Ethernet cable to your modem and the other end to the internet port on your router.
Step3: Plugin, then turn on your modem
Wait approximately 2 minutes, if your modem has a battery backup, first remove and reinsert the battery before connecting your modem to power.
Step 4: Connect the power adapter to the router, then plug it into an outlet. Wait until the wireless LED turns solid green.
Step5: Connect the router to your computer
To know more information
How To Setup Belkin Range Extender TechVaidya
Sep 07, 2012 | Belkin N Wireless Modem-Router F5D8633au4A
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Can't configure belkin n wireless router.
yes always best to use ethernet when you can.richardm69
Feb 03, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless Modem Router problem
well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
May 28, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Open Questions:
Belkin Wireless-N Wireless Router with 4-Port Switch Logo
116 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
