NexxTech (EDP 3100) DVD Player
Can't get my nexxTech (EDP 3100) DVD Player to give a picture or sound to my TV screen. Checked troubleshooting recommendations in manual, everything appears to be as it should be but still nothing on screen.
No solution yet. Waiting for someone to come through with a suggestion. Thanks.
Posted on Jun 24, 2008
Moved and lost my remote, but can't find a code in the Universal Remote booklet for this brand.
astar dvd 3100 remote code Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your astar dvd 3100 remote code question. Get free help, tips ... Ican't program the dvd to a universal ... dvd to a universal ... My VCD can play on DVD-3100 DVD player, but DVD disc can play on it. It always show "bad disc" ...
hd 3100 DVD & Blu-Ray Players Questions & Answers - Fixya
www.fixya.com > Forum > Tags > hd 3100
toshiba HD-A35 region unlock I am looking for an unlock code for the region ...nexxTech (EDP 3100) DVD Player Can't get my nexxTech (EDP 3100) DVD ... i need to find where i can buy a remote in b.c. canada i need a remote for my astar dvd ...My VCD can play on DVD-3100 DVD player, but DVD disc can play on it.
Lost Remote, Need Code For Universal Remote jx
www.hivmr.com/db/jx97xsd37ad83fd1mksxzxkf88ca3fa9
I recently moved and lost my DTV remote, I have a Phillips PM625S 7-device .....Need remote code for ASTAR tv's .... Need remote code for Sylvania Model 6719DF TV/DVD/VCR combo. ... DB:2.37:Remote Code For Vizio Vbr120 Blu-Ray Player 88 ...Would like to programme my SKY remote but can't find the code ...
Jan 18, 2016 | Astar DVD-3100 DVD Player
What is the DVD player code for Model EDP 3110
go please to www. remotecodelist.com or memorex.com and download for fix it.
God bless you
Dec 06, 2013 | Televison & Video
Tv has sound but no picture.
Hi, troubleshoot first before going to the board of the TV to be sure where the problem is from.
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
After troubleshooting the above and no solution yet, problem comes too from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacing the fuses and the capacitors and still no solution,you will need to replace the all board ..
Hope it helped ..
Jun 01, 2011 | Televison & Video
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Black screens, set checked everything but can not
The only "kill switch" I am aware of is the switch on the DVD compartment door. I don't have your exact model but, on my model, this switch is activated when the door covering the DVD is closed and deactivated when this door is opened (kills the DVD spin and reading laser). Look for a small square hole in the DVD player deck and a corresponding raised piece of plastic on the DVD door.
Oct 07, 2009 | Venturer 3.6" Portable DVD Player
I have a nexxtech universal remote and a philips dvd player, How do I program, lost the manual
i both a universal remote control from nexxtech for my electrohome tv a month ago .
And its not working anymore , i lost the code to reprogram it . Can you help me to get that code
Sep 02, 2008 | NexxTech PDN-0705 Portable DVD Player
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
My LG DVD Player gives off sound but no pictures even after correctly connecting the cables. It used to give off both the sound and pictures before I touched a button on the remote control
I don't know the particular model, but I can give some generic type suggestions.
Look in the user book to see if there are any resets. If you can see the menu on the screen, check the default video output. It may be set in a format that is not compatable for your TV set. I have seen that from time to time.
I am assuming you checked all the interconnect cables and that there are none that are defective. You also checked that the input on the TV you are using is working properly.
Jerry G.
May 12, 2008 | Televison & Video
Hook up dvd(nexxtech edp3110) to emerson ewv403 and then to sanyo tv(ds13204)
Hey why dont you use a video sender incase your intrest is the picture and then search the channel on tv
Mar 21, 2008 | Emerson EWD7003 DVD Player
NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
