Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
TV picture goes out after 10 minutes of viewing with popping sound
After using the set for 10 to 20 minutes, I hear poping sound and then light flickring and picture goes out. Or sometimes picture goes out after 20 minutes without a pop sound but red sometime white light flash and goes to blank screen. But power light stays green until I turn the tv off from remote.
After leaving the tv set off for 10 minutes, I can turn the tv back on and picture comes back on. And same cycle can be repated all day.
Any solution to this issue..
thanks
sk
  • 4,472 Answers
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Posted on Jun 24, 2008
  • Lee A.
    Lee A. Jun 24, 2008
    You do not want to turn the TV on in this condition as you may damage other parts.
    Lee
  • Lee A.
    Lee A. Jun 24, 2008
    Most likely it is the overload circuit protection. If you feel so inclined, you can look inside the tv for any capacitors with bubbled tops, or anything else that looks fried.
    ONE: Do a hard reset - this will just make sure the power management
    system or the protection circuits have not gotten corrupted. Unplug
    the line cord for 4 hours. That will reset all the internal codes to
    factory defaults.
    TWO: Just try the whacking test (it is a common problem in big sets,
    especially). Whack the set with your fist in some strategic places;
    back, top, sides, etc., If you have the back cover off, using a long
    wooden (non-conductive) stick, probe around gently to see if you can
    find a place that brings it back to life. This testing is for loose
    wires, poor connectors, corroded pins, cold solder joints, etc. that my
    be acting up.
    THREE: If the above two procedures provide no indications, then the set
    has something internally that needs mending. The excessive current
    that is causing the protection circuit to go into action could be from
    the high voltage section, the vertical or horizontal deflection
    amplifiers, the audio amplifier or the main power supplies.
    Unfortunately, it is impossible to know without a hands-on diagnostic.
    The most common is high voltage generator failures and/or deflection
    amplifier breakdowns.
    FOUR: Fortunately, these are common failures, albeit expensive, and
    most good big screen techs know how to get at them right away. The
    cost will be for a house call and repair labors. Maybe as much as $300
    for repairs, plus or minus.
    NOTE: Make sure, if you have a tech come in, they are trained in
    working on big screen sets. Lack of experience is the most common
    complaint about house callers.
    Hope this helps,
    Lee
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
I bot a used zeinth C32v-23-8 Hd tv and when I pluged it in it makes a poping sound and you can see a light flashing inside and has sound but no picture
Sounds like a High Voltage lead in the set is arcing--What I also remember from this set is there is a tiny blue cap (with back off and looking from rear) to the extreme right side of the main board that burns to a crisp.
That is fairly easy to fix.
Let me know what you find.
Apr 02, 2012 | Televison & Video
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Pioneer projection tv SD-582HD5
I had the same problem, try running the TV on Mute, if it is a bad solder joint the sound can vibrate the solder point and trip the relay, if the TV doesn't trip off with the sound on mute then it is probably the big power transformer's solder connection needs resoldered. sound vibration from those big pioneer speakers may loosen the solder joint over a period of time because the transformer is heavier and bulky and vibrates a lot.
Jan 10, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
326 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
