Question about HP LaserJet 2840 All-In-One Printer
Unexpected noise Every few hours my HP all in one come alive and starts making sounds as if it is printing(even in the middle of the night), the computer towhich it is connected is turned off. I called HP. The tech support guy told me about checking Calbration in device setting in toolbox. I entered calibration timing :NEVER. It stll makes the sounds once or twice a day! Can any one help.
  • yusufp32 Jun 25, 2008
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this printer plugged into a surge protector?
I know this will sound stupid, but just cut it off at night.
Posted on Jun 24, 2008
HP 8600 makes clicking noise takes long time to start printing
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Signs my 95 chevy tahoe fuel pump is failing
For how long after does it make noise it's not uncommon for the pump to stay running 3-7 seconds after shut down however if it getting noisy you may need to change your fuel filter restrictions in the system will make it noisier
Aug 31, 2012 | Cars & Trucks
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
I have a 2002 c 320 battery isn,t dead but car won,t start.I even changed the battery and still the same it also did the same thing last week but started after an hour or so
under what condition the car won't start?
is it when the car set over night, a few hours or after a few minutes.
does it make any noise or click when you try to start?
does the engine even turn over at all or just silent?
if nothing happen then may be the starter, switch or fuse.
if the engine turn but won't run then may be the ignition system or fuel system.
Mar 10, 2010 | 2003 Mercedes-Benz C-Class
Hi our 3 in 1 printer keeps freezing can you give
This is a problem with the formatter board, contact hp tech support, 1800 334 5144, and if it has been under 2 years since the purchase date they will offer the standard warranty options or you can have it serviced at a local asp under a service note.
Sep 23, 2009 | HP M2727NF Laserjet Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
''clicking'' noise started randomly- cant use printer
Hi starrz54,
Here is the HP site that talks about resolving unexpected noises (such as clicking)...
You also might try doing a full reset on the device. Here is how to do that: While switching on the scanner press # and 9 to initialize.
This should give you some good directions and if it does not resolve the issue, the next step would be to have it serviced or replaced.
Nov 16, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 1610 "clunks when starting print job"
There are a number of potential causes and solutions to this sort of issue. They all seem to be hardware related, but has a web page with links to solutions that may apply to your situation:
Unexpected Noises when Printing
Hope this helps. Good luck.
Aug 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP LaserJet 2840 All-In-One Printer Logo
Ben Johnson
