Question about Canon PIXMA iP90v Printer
IP90V Paper will not feed through printer, tryed to clean heads but would not feed the paper tp complete the job. Printer is only 6 months old but cannot return because I don't have the receipt. Help maual said to clean roller but can't find the info on how to.
    Sergeant:
    Champion:
  • 230 Answers
This may be due to the fault in the head roller only, so do clean that one i will get you the manual for it
Posted on Jun 23, 2008
  • balachander megavarnam
    balachander megavarnam Jun 23, 2008
    and also make sure that the paper that you are inserting should not
    have any crushes or foldings like that ,then will also this problem
    will arise
  • Canon Master
  • 13,433 Answers
The shop where you purchased the product should have a receipt ther with your name.
check to see that there is no paper stuck anywhere and clean the rollers with alcohol.
  • Ekse Jun 23, 2008
    here are cleaning instructions
    If paper does not feed correctly, perform the following to clean the paper feed rollers:
    1) Confirm that the printer is powered on.
    2) Remove any paper from the printer.
    3) Press and hold the button.
    4) Release the button after the Power lamp blinks three times.
    Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
    5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
    6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
    7) Press and hold the button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
    8) Repeat the process as necessary
    Master:
  • 848 Answers
If the printer won't feed paper, there is a good chance that gears are stripped or rollers are worn-down or have flat spots.
  • 1 more comment
  • gopinath pasupathy Jun 23, 2008
    try to do deep cleaning process
    If normal printhead cleaning is not enough, click the Deep cleaning Icon found in the Printer Utility. Click 'OK'. The Power lamp will flash and print head deep cleaning will start.
    you also check noozle check pattern
    roller is placed on left side of printer check whether a bit of paper is struck there this may also lead to the problem
    Genius:
  • 1,847 Answers
If you open the tray you will see the roller, just chk for bits of paper there
Why does the paper jam and a loud noise come from the iP90 printer?
Most likelt to be a foreign object or wad of paper crammed into part of the paper feed roller. The first thing to do is turn it upside down and give a few sharp solid taps on the bottom casing. Then check to see if anything falls out. Also check the leading edge of the paper that didnt go through for marks that might show where it was stopped. If you are sure there is nothing to stop paper feeding through, check at each end of the print head path inside for a clump of ink soaked paper - remove if found. Try feeding a sheet through again. If the paper doesnt feed, try slipping a thin stiff card or plastic sheet back through the feed mechanism from the front. If that doesnt go through, you will have to disassemble the printer to find the problem.
Jun 27, 2014 | Canon PIXMA iP90v Printer
When i try and print it say's paper jam all the time .
Great job on removing the paper jam and trying it with a different paper. If you have already tried using different media, using 1sheet or multiple sheets on the feeder but still no difference, most probably a mechanism problem in the printer. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. A 6-month old printer shouldn't cause you that much trouble.
Jun 23, 2010 | Lexmark X5650 All-in-One InkJet Printer
Paper gets stuck each time new printing job
I suggest you clean the head of the printer, by carrying out maintenance clean up on the printer.
Go to the menu, scroll down, you will see maintenance option,click on this and chose clean cartridge.
If this did not solve the problem, uninstall the printer driver and reinstall. Also try to carry out general service on the printer.
Also, check the ink level of the printer because if the ink is low, it causes paper jam.
Wish you best of luck.
Apr 03, 2010 | HP PSC 2210 All-In-One InkJet Printer
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
When I print blue horizontal lines appear or being printed as wel
Do the cartridges ride on the printing carriage, or do they plug in somewhere else in the machine and have hoses that run the ink to the print head? If they ride on the printing carriage and the cartridge is new, there could be a short in the printer and it needs repair. Check if there's ink smeared on the print head or part of the printer. Generously clean the print heads with lots of paper towels and rubbing alcohol. If that doesn't work, to see if it's an issue with computer, print a test page from the printer, but don't send the print job from the computer. You need a print job generated from inside the printer itself. Not every printer can do this, but try pressing paper feed, holding down paper feed and power, or holding down cancel and power. If the blue lines disappear then but they didn't when you cleaned the heads, it's a software issue.
Sep 17, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Paper Feed Problem
Hey I had this problem too for about 6 months. Just press the "Feed Switch" button under the main display to switch it from feeding from the tray under the printer.
Sep 20, 2008 | Canon MP610 Photo All-In-One Printer
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
Canon PIXMA  iP90v Printer Logo
188 people viewed this question
old marine
old marine
