Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Error 542 I saw your solution on the site here and I can't find any online or escape buttons on the printer... At least none that are labeled that way
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Enter Service program mode > Press Clear mode (yellow) button,
> 1 0 7 and press and hold Stop (red) button.
Select copy SP and switch off and on the machine.
If sc 542 is still there, probably you have a defective thermistor or fusing lamp.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Why do I have error code SC542 on richoh aficio sp6330N
542 is usually a fuser error. Thermistors. You should give your local Ricoh agent a call let a technician come and fix thermistors with new ones.
Jul 02, 2014 | Ricoh Aficio SP C231SF Color All-In-One...
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
Jul 30, 2012 | Toshiba TEC B-572 Printer
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Apr 24, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Mar 07, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
454 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
