Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven won't light
Broilers both light, oven won't.
    Scholar:
  • 170 Answers
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Posted on Jul 20, 2008
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Gas oven won't light and the broiler won't light
Hello, welcome to FixYa.
I've read your previous post's and can see a couple of scenarios have been thrown out there, so this may just add fuel to the fire...no pun intended.
It sounds to me like a tripped hi-limit safety thermostat is the culprit, hence neither ignitor so much as glows. I'll explain. If the valve where faulty the ignitors woul;d still glow as it is the ignitors which allow the valves to open not the other way around.
Further to that, if the ignitor where faulty, it is unlikely it would be both at the same time, however if a hi-limit safety tripped it shuts down power to both the broil and bake ignitors thus no oven function at all...that is it's function "safety".
The hi-limit safety on your range is on the back wall so you need to slide the oven out (if you haven't done so by now) to inspect it. To do so is pretty easy, one of two ways.
You can jump across it to see if it allows the oven to operate or you can ohm it out with a meter. it should simply be a closed circuit if good, open if not. It is the non-reset type unfortunately so you'll need to replace it.
example
It is part number 8300802 and available at "repairclinic.com" or "searspartsdirect.com" to name just a couple.
Let me know what you find and I'll be glad to help you moving forward from there. Good luck.
Regards,
Macmarkus :)
Posted on May 31, 2011
ginko
  • 19396 Answers
SOURCE: Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Posted on Dec 13, 2011
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
Hi.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
140 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
