Question about Brother MFC-8220 Fax
F ed up fax mahine
Ext tel in use on all the time. unless I unplug the phone line
    Genius:
  • 2,120 Answers
Is the hand set on correctly? (unlplug it if you can)
make sure the phone line is plugged into the LINE port.
Unplug the power cord for 10 seconds.
Posted on Oct 11, 2008
How to send regular fax from a bizhub c250
fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 02, 2014 | Konica Minolta bizhub C250 All-In-One...
How do i send fax from bizhub 250
Fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Apr 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
I wish to use one line for both my landline and fax how is this done
Connect the line in the fax (LINE JACK) AND THE landline in the fax jack MARKED AS TEL.
Dec 17, 2012 | HEWLETT-PACKARD HP 2140 Fax
Brother fax p275
Remove the backup battery and unplug the fax machine and leave overnight. By morning I'am hoping it will wipe everything clean when plugged back in along with the battery. But it will mean you will have to set your date and time again.
Mar 07, 2012 | Brother Office Equipment & Supplies
Can i connect a phone to another room to the machine , if so which one do i plug the phone into and which one do i plug the one from the wall?.....there are two places to plug them into.......one says...
The "Line" jack is the one for the Telephone line over which you send the fax's.
There should also be a jack marked "ext tel" or possibly "ext phone"...this is the one into which you plug the telephone.
Jan 05, 2011 | Office Equipment & Supplies
My Brother fax 2820 has a message on screen saying Ext Tel in use. I have recently moved the machine and have had this message each time
That message means that a telephone "somewhere" has access the line that the FAX is plugged into BEFORE the fax. The most likely cause is an extension phone or maybe a computer modem (if you still use a phone modem)
If you want a manual you can download it here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
Dec 18, 2010 | Office Equipment & Supplies
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
Mar 26, 2009 | HP Officejet 7210 All-In-One InkJet...
Canon faxphone will not recieve fax
Most of my fax mahines I setup,I setup with the fax only mode,and then I change my incomming ring to 7.This give you enough time to answer the phone and minnimize the risk of losing faxes.If a external phone is connected to the phone and you receive a fax call,you press 25 on the external phone and the fax switch to rceive.
Feb 27, 2009 | Canon FAXPHONE L80 Laser
The machine looks busy to outside callers, but is not in use. Whats up with that?
Unplug handet (left side) to eliminate it being the problem, make sure tel line from wall goes to fax'x line socket (not ext), plug a normal phone into same wall phone socket fax uses and see if that has dialtone, phone line requires filter if using asdl
Oct 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Strange error message
This is usually an indication that a phone is off the hook somewhere in the building. Hook up a regular phone to the wall jack that the fax is hooked up to now. Check to see that you have a dial tone. If not, then the problem is somewhere else. Hope that's it Ed
May 25, 2007 | Brother IntelliFAX-870MC Fax
Brother MFC-8220 Fax Logo
231 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
