My dvd player will not read any disc
Talked to somone yesterday on this site,they told me to take machine apart and clean lense.i did this probably 15 times and still wont read disc
  • jeanniebenny Jun 25, 2008
    my machine is about 8 years old and a lot of movies have been played through it, dont think its a stuck laser because it has no problem moving just wont read disc
    Scholar:
  • 135 Answers
Need more info on problem to solve it. Depending on age and amount of use, it could be just a stuck lazer, blocked lazer, gears on lazer track may need 'grease'(very little, applied only to gear teeth, then move the lazer manually(very lightly-do not touch lens) . Or the lazer itself could be burnt out. You don't give enough symptoms to go any further.
Posted on Jun 23, 2008
How do I get to the lense in my broksonic DVD VHS player. My DVDs wont play anymore and I think it needs cleaned. I can't figure out how to get the actually laser cover off.
you don't you buy a laser cleaner disc. This disc has small bristles that clean the lens inside the machine without having to take anything apart.
Nov 15, 2016 | Broksonic Televison & Video
My bush DVD player keeps coming up bad disc why is this?
Hi Grace,
Coming up bad Disc means your DVD player is not able to read the discs. There may be some dust on the lense ( optical unit ). If you can clean it please do it. If it does not work even after cleaning, the lense is bad and needs replacement.
May 30, 2015 | Bush Televison & Video
How do I clean Discs Lens
I don't know about that model in particular, but in the rare occasions where I've felt the need to clean a disc player lens, I've always taken apart the chassis and taken the lid off the disc assembly, which is usually a separate box with various wires coming out of it to connect to the circuit board in the main chassis.
With the lenses exposed (after taking it apart), I spray some glasses lens cleaner on a lint-free glasses cleaning cloth, and gently wipe the moist end of the cloth over the lenses, using the weight of the cloth only to contact the lenses.
The lenses are held by a very delicate mechanism for focusing by a magnetic field, and if you touch them directly you will very likely damage them and cause the focus to go permanently bad. DON'T TOUCH THEM.
Also, the laser output can damage your eyes. Make sure it's unplugged when servicing it.
If you've never opened up an electronic appliance, don't try to open it to clean it. You'll probably break the whole thing if you don't have experience.
You can try one of those cleaning discs but I don't know if they really work. It's hard to get something close to the lenses without damaging them.
Mar 31, 2013 | Magnavox DV220MW9 DVD Player VCR
When I insert a disc I get a "Disc Error" after
Most DVD players display that kind of error when unable to read data on you disc media. Try other DVD disc if that post the same problem. A new one will test if it is the unit problem or the media disc problem. If it post the same problem on a disc that runs well on other players then your player probably has a dirty lens. You can clean the lens using commercially available DVD lens cleaner on the market.
Jun 14, 2011 | LG DP450 Portable DVDDivX Player
No Read on DVD player/recorder
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Mar 04, 2009 | Panasonic DMRES15 DVD Recorder
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
Dvd player won't play disc
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
Jan 12, 2009 | Samsung DVD-V4600 DVD Player/VCR
Sony blu ray player
Hello Thank you for choosing FixYa.com for your answers my name is David.
If it takes it a while to read sounds like one of 2 things or a combonation.
your reading lense that reads your discs may me dirty or you may have dusty
or damaged disk. most likely your machine is dirty I would go to your local store
and ask them for advice on the best type cleaning disc for the blu ray player
walmart has decent prices for that sort of thing good luck and thank you again for choosing FixYa.com
Nov 08, 2008 | Sony Blu-ray/dvd player BDP-S1
DVD Recorder/Player..Not Reading Dvd's,Takes 1-2 Minutes, Then Nothing
Try cleaning the lenses with a cotton swab and alcohol. Other than that the only option is to replace the optics assembly.
Dan
Mar 19, 2008 | Televison & Video
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
