Question about Canon Pixma MP450 All-In-One InkJet Printer
Ink absorber is full on my MP450 Canon Printer
Light comes on saying that the ink absorber is full. Where is it? I wish to empty it but I cannot find it?
  • 4,041 Answers
Here this step by step to resetting waste ink counter printer Canon Pixma MP450
  1. You will turn off printer.
  2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
  3. you will let go button Resume/Cancel, continuing to retain POWER.
  4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
  5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
  6. you will turn off printer by button POWER.
Posted on Feb 07, 2010
My Pixma iP1200 is reading ink absorber is full - can I fix this myaself? How do I empty it?
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 30, 2013 | Canon Pixma MP450 All-In-One InkJet...
I have Canon Pixma MP450, the error is 5B00? how to Fix it? Now cannot use the printer due to this error. Thank you for your attention
Error 5B00 means that your ink absorber is full. you need to reset the counter protection and replace the ink absorber inside the printer.
Visit the link below for instruction on how to reset the canon mp450 printer EEPROM
http://pcmediks.blogspot.com/2010/09/how-to-reset-canon-mp450-printer.html
Dec 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
My Canon Pixma MP450 keeps reading ink absorber full. What does that mean?
Like peeling potatoes or oranges or apples, and throwing the peel into a garbage-bin, eventually the bin will get full, and you'll have to empty the bin, before you can do more peeling.
Similarly, when printing, some INK is "wasted", and ends up in a small bin, with an ABSORBER pad (like a baby diaper) in the bin.
So, your printer's bin has become full, and a qualified printer technician can properly empty the bin.
Dec 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
May 16, 2009 | Canon Pixma MP450 All-In-One InkJet...
Ink aborsver full
u will need to take the printer to canon service centre and get the printer serviced this problem comes when sponge in the purge unit exceeds its absorbing capacity
Feb 24, 2009 | Canon Pixma MP450 All-In-One InkJet...
WASTE INK NEAR FULL
Use paper towls and absorbe the ink out of the waste ink tray.
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Waste ink absorber
You'll always find the wast ink absorber under the printer head after printer head prints and rest, there is a rubber type clip which cleans the head and the ink drips down on the cushion absorber. Disassemble the printer and remove the cushion than dip in the bucket of water until ink dissolves out of the cushion and wash under running tap until clean then dry and finish, put back the item and assemble the printer.
Nov 06, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Printer Problems
Open the printer, locate the absorber, wash it, then centrifugate to get it dry, install it again and reset the printer.
The absorber is like a sponge filled with ink when it's used.
Apr 30, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
322 people viewed this question
old marine
old marine
