Question about NEC ND-6650A DVD RW Dual Layer Burner
DVD dead?? After a year or so working fine, my DVD RW became invisible to my computer. It spins up when a disc is inserted but never shows up in MyComputer list therefore never reads any data.
  • caglaryjohn Oct 02, 2008
    My registry is corrupt and the dvd is not recognized. Nothing seems to help. I cannot do a system restore at all. dell says the only thing to do is a PC restore but that is scary?
    High and low filters have been taken out too.
    At witts end.
EASY. TRY TO REPLACE YOUR OLD IDE CABLE CONNECTED AT THE BACK OF YOUR DVD. BUY A NEW IDE CABLE IT MIGHT SOLVE YOUR PROBLEM.AND LASTLY MAKE SURE THAT THE IDE CABLE IS WELL SEATED ON BOARD AND ON DVD.
Posted on Jun 23, 2008
I recently have not been able to record on DVD+RW discs. An error message keeps coming up saying it cannot record on this disc.The dumb part about it is I still have a couple of discs of the same nature...
According to the user's manual, for DVD+RW or DVD-RW discs, it may take some time for the disc to be recognized and then it has to format the disc prior to using it. This should be an automatic process when the disc is inserted (looking at page 17 of the owner's manual). If this is not happening, you may need to clean the DVD with a DVD cleaner (a DVD disc with tiny brushes that wipe the lense on the unit while the disc spins). You could first try using a can of compressed air and blowing any dust/dirt out of the DVD slot (with the tray open).
Feb 09, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My cd drive shows empty even with disc inserted
If the disks you insert DO work on some other computer,
then it's time to spend $40 and buy a new CD/DVD-writer,
to replace the "dead" unit.
The "working properly" part is ONLY an indication that the hardware has been detected, and the correct software device-drivers have been loaded; it makes no guarantee that the unit will work.
Compare it to having a car -- it looks like a car, but if won't start, it still is a car, although it cannot be used as a car.
Dec 29, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Burner wont read any disc
you burner is suppose to read disks even when its not on a pc. check that out, ie disconnect it from the pc and insert a audio cd jus to check if it reads the cd, its suppose to spin and not stop. that shows its reading. if it doesn't then its dead. you will need to replac it
Dec 09, 2009 | NEC ND-3550A-KIT DVD±RW Burner
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
Amilo PA 2548: DVDRW GSA-T20N can't write discs
Go into device manager and delete that disk drive and then reboot and it should reinstall it. That will separate the drivers and put the old one back.
Jun 10, 2017 | LG GSA-T20N DVD±RW Dual Layer Burner
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 14, 2009 | Acer Aspire L100 PC Desktop
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Problem with HD writer 2.0E
The reason for this error is that there is a conflict between HD Writer and other software on your computer. I was trying to find a solution for weeks before Panasonic advised me to remove other DVD burning software on my computer. I therefore removed Pinnacle and DVD decrypter (which I believe was causing the problem), reinstalled HD Writer and then everything worked fine. Note however that the DVD-RW discs I had tried to use before were corrupted and couldn't be reformatted and therefore once you have removed the other software and reinstalled HD Writer, start again with new DVD-RW discs. Good Luck.
Jul 23, 2008 | Panasonic HDC-SX5 DVD Camcorder
Dvd-rw doesn't work
Try to find a boot CD .Put that CD and try to start you computer and see it work or not.Incase it doesn't ,that mean you have a bad CDROM,you've to replace with the new one then.
takecare.
May 08, 2008 | Everex StepNote VA4103M Notebook
NEC ND-6650A DVD RW Dual Layer Burner Logo
172 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
