Question about GE 13TVR72 13 in. Combo
Video stuck in vcr/dvd combo
I put one of our home videos in to record it onto a dvd and it won't play or eject. It did not go in easily. Did I break something by forcing it in?
3 Suggested Answers
SOURCE: Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Posted on Jul 01, 2009
  • 4345 Answers
SOURCE: I have a 19TVR62
That sounds like dirty heads. Try a cleaning tape, but I have never had those work. You need chammy swabs, and rubbing alcohol and you clean the heads manyally. Hopefully your vcr comes out with only a few screws.....
Clean the heads parallel to tape path, not up and down the video drum. If you do parallel direction, it is hard to damage the heads...
Clean other items along the tape path and remove all hairs that you can find..but hte heads are the part not working, common for tape dust to accumulate and harden.
Posted on Feb 02, 2011
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Sony rdr dvd recorder / vcr combo.... I put a instructional video and the dvd won't go past the copy write warning.
have you checked the cd for deep scratches because i had a dirt bike game that did the same thing
Mar 05, 2013 | Sony RDR-VX525 DVD Recorder/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Go video vr3840 dvd/vcr player recorder combo
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
GE 13TVR72 13 in. Combo Logo
77 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
