Question about HP DesignJet 450c InkJet Printer
Plotter only printing in Cyan
My plotter is a DesignJet 450c. Up until recently it worked well. The last couple of prints have pinted in light blue. The files are in PDF format. They are supposed to print in all black.
Check your black cartridge. Do the pump the cartridge thing with the plunger on the left of the plotter. Check all the electrical connectors on the cariage and the cartridge - clean with water -or wd40 if you are very careful and check that all the contacts, about 40 of them are clean and undamaged on each cartridge. Replace with known working cartridges. run a color test as specified in the manual -- hp has relased the manual for this printer as they no longer service this unit.
Posted on Aug 06, 2008
I have a hp 450c plotter and it will not print.
Has this USB to Centronics cable worked in the past, but has now stopped?
The reason I ask is that there are two kinds of parallel ports, and so two kinds of USB-to-Centronics adapators. One is unidirectional, and one is bidirectional. If your plotter requires bidirectional, then it won't work properly with unidirectional.
Jun 10, 2010 | HP DesignJet 450c InkJet Printer
Our 450C plotter is connected via E-Net Hub and has extened memory. The "Test Printer" works. However it will not complete an Auto Cad Drawing. The ready light continues to flash but the plotter stops. any...
This could be one of a number of things. The file being sent must be smaller than the total memory of the printer. Connect the computer directly to the plotter with a parallel printer cable and see if it prints. If you are using an OS newer than XP, try using the XP 32 bit driver. If you are printing from AutoCad 14 or older, upgrade AutoCad (newer uses Windows printer drivers). If you can print OK with the parallel cable, get new external JetDirect software from the HP website.
Jan 15, 2010 | HP DesignJet 450c InkJet Printer
My HP Designjet 450C prints part of the document.
Steven, it's either lack of memory or the trailing cable is faulty and flexing open circuit at a point as it crosses the carriage rails
Sep 07, 2009 | HP DesignJet 450c InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
Hp designjet 450c error lights
Take all cartridges out while the plotter is on,then re-insert them one by one and watch the ready light flash after each insertion.If it doesn't flash that could mean 2 things,either the cartridge is bad or the contacts on the carriage are dirty or the entire carriage needs replacing.
I tell all of my dj-4XX customers to check the spittoon assembly(on the inside,right side)for ink buildup. If it looks clogged,you can temporarily scoop the ink that solidified out,but eventually it(spittoon)will need replacing.
Hope this helps
Jan 09, 2008 | Xerox Phaser 7750DN Laser Printer
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
166 people viewed this question
Ben Johnson
