Question about Zebra Eltron TLP 2844 Thermal Label Printer
Zebra TLp 2844 (printer not connected error message )
Hi I have a Zebra TLP 2844 for barcode and label printing. It works fine for some time but after a while it does not function. The error message I get is printer not connected. The other error i get is spooler not functioning... The printer screen just goes blank. The OS im using in XP.
I have to then restart the machine to obtain a print. Any solutions?
    Scholar:
  • 45 Answers
Go to Control Panel, Administrative Tools (in Clasic view), and double click on Services. Scroll down and right-click on "Print Spooler". Start (or Restart) it and your printers will reappear in the "Printers and Faxes" window, and the spooler will try to send jobs to the printers again.
If you check the Properties of the Print Spooler, on the Recovery tab, you can set it to "Restart the Service". I set mine to Restart on the First Failure and Second Failure, and Take No Action on the Third Failure, in case something really needs attention.
Posted on Sep 23, 2008
Zebra TLP 2844-Z appears to print from the iSeries/AS400 but nothing prints no error message Set up same as other Zebra printers that are working printing bar codes
check the connection configuration (if is com port, check speed, flow control and others)
Try to install locally with segull drivers (www.seagullscientific.com) if you need, reset to factory defult. print a test label from the driver. if is comunicate, is not printer problem, is connection problem with your software.
Aug 17, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
Jun 03, 2009 | Zebra Eltron TLP 2844 Thermal Label...
I need the exact ribbon and label model to buy for TLP 2844 barcode printer
Contact Labeltronix at 800.429.4321. One of our sales reps can help you with your label/ribbon combination for your application. www.labeltronix.com
May 12, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Eltron TLP 2844 Thermal Label Printer Logo
367 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
