Electric typewriter set the margin
I can not get the margin to move over any further than 1/2 way to the right, it is an electric typewriter, how do you cahnge the margin?
  • 1 more comment
  • pkptroco_3 Sep 08, 2008
    I need to know how to set margins on a Royal electric typewriter.
    model # RT7700
  • Jim Keysor May 11, 2010
    Electric or electronic typewriter. Electric typewriters usually have manual set margins such as the IBM selectric whic are or should be sticking out the front cover. They do fold up inside so they don't stick out. Again what kind of machine is it?
  • mopli swami
    mopli swami Jan 11, 2014
    I need to know how to set both sides of the margins on Electronic typewriter GX8250
    Scholar:
  • 183 Answers
If you still have problem, repost with make and model typewriter, different methods are used with different machines
Posted on Nov 01, 2008
Need to unlock the margins of a Brother ML500 memory Typewriter
Move the carriage (print head) to the margin you would like to clear. When you hear the beep, hold down the [ALT] key and press [3]. Now use the backspace or the space bar to move the carriage to where you want the margin set. Now hold down [ALT] and press [4] to set the left or [5] to set the right margin. For your further reference, I have included the keyboard special key chart. You might need to download the pic and zoom in to read it.
Dec 22, 2010 | Brother Office Equipment & Supplies
How to do margine release
Dec 07, 2010 | Brother SX-4000 Typewriter
Change margin
Do you see the lmar and rmar above the number keys printed on the cover? Move the carriage to where you want to set the left margin Then hold down the ALT key and depress the corresponding number key under the lmar symbol. Repeat for the right margin.
Jun 18, 2009 | Brother ML-300 Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
I have a typewriter brother I have a typewriter brother ML300 and I cant figure how to ajust the margin.....please help
Left Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current left margin, press (ALT) + (M REL) (3). Press (ALT) + (L MAR) (4). The left margin is now set.
Right Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current right margin, press (ALT) + (M REL) (3). Press (ALT) + (R MAR) (5). The right margin is now set.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Feb 06, 2009 | Brother ML-300 Typewriter
Right margin gone awry! No Manual.
May be a little too late now but...when you get to the right margin and it beeps and you can't go any further, press the mar rel (margin release) button on the top left. Move to where you want the right margin to be and press the mar right button. This will set your right margin farther out.
Jan 08, 2009 | Olympia Startype 3 Typewriter
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
Aug 10, 2008 | Brother EM-530 Typewriter
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
Unable to set margins
To set the Left margin:
1) Move the carrier ro the place you want to set the left margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current left margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[L MAR(4)]. The left margin is now set.
To set the Right margin:
1) Move the carrier ro the place you want to set the right margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current right margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[R MAR(5)]. The right margin is now set.
That is directly out of the manual. I will upload the manual to FixYa, and you will be able to view it from the ML-500 Typewriter's product page: http://www.fixya.com/support/p131634-brother_ml_500_typewriter
-John
Feb 06, 2008 | Brother ML-500 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
920 people viewed this question
jasbo
jasbo
