Question about Sharp YO-P20 Handheld
Electrical contacts can you recommend a contact cleaning fluid ? austin
  • 4,472 Answers
You can use an eraser from a pencil or an eraser like it to clean the contacts off, this is the easiest and safest way. Otherwise just buy the electronic wipes that you can purchase at most electronic stores.
Keep me updated.
Thanks,
Lee
Posted on Jun 23, 2008
Ml350 transmission won't shift code p2767
check the oil level in the gearbox if this is to low it wont shift
Feb 14, 2014 | Mercedes M-class Ml Ml350 Ml550 Ml63...
What will happen on my cam if the battery has leaked, specifically on the card holder? Will it be rusted?
It will corrode the battery contacts and the recharageable battery will have problems making electrical contact..
Remove the battery fluid and clean the contacts with methylated spirits.
Mar 25, 2012 | Nikon COOLPIX L19 Digital Camera
I changed the Magenta toner & print head. Everytime it does the check, I get the error message to reseat Magenta. I cleaned the contacts with the pads provided with the printer. What do i try now.
Your electrical contacts in the carriage assembly are either defective or dirty...try using an electrical connection cleaning solution. If the cleaning does not work. There are companies that sell used units that are very affordable compared to new.....I recommend www.getthatpart.com ....They have these carriages used for cheap and they guarantee their items and sell 1000's of parts....You can give them a call and a live person answers the phone to help with your questions.. highly recommended!
Oct 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Power steering
bad electrical signal to the pump. pumps thinks its going fast. the valve that controls the fluid flow to make steeering stiffer at higher speeds is confused.
use electrical contact cleaner and d-electric grease to fix contact problems.
pop the hood and cleans as many connections as possible, let dry and apply a small amount of di-electric grease to those connections, then re-connect the plugs. even do the dme connections to the main wiring harness.
this will solve many electrical contact problems seen in older cars.
Jun 24, 2009 | 1997 BMW 328
E brake light on 2005 scion tc will not go off
The same light will come on when your brake fluid level is low in your master cylinder. If its low, just add brake fluid. Then check you front brake pads. The may need replacing soon. (thats why the fluid is low)
Jan 12, 2009 | 2005 Scion tC
Door ajar lights (sliding door) even when closed. Sliding door will not lock with remote or manually. Wiring diagram would help....
Clean the electrical contacts attached to the side of the sliding door and the matching set of contacts on the pillar using fine grit sand paper. Once shinny surface of contact metal are exposed, spray contact cleaner on these contacts and wipe excess fluid. Contact cleaner is available in spray can container at Radio Shack outlet. Let me know if this solve your problem.
Nov 08, 2008 | 1999 Honda Odyssey
2005 Honda odyssey sliding passanger door is clicking when opening or shuting. to check to fix the problem I would like to know what
Sep 21, 2008 | 1999 Honda Odyssey
Craftsman twin cylinder 19.5HP, no spark on plugs with switch interlock wire removed from the ignition module. Cleaned magnet and set gap to .010 (recommended setting on coil) wrapped wire on threads of...
I was able to solve the problem after I scanned several answers that were given on your site. The ignition module was defective and I purchased a new one, set the gap and it fired right over. Thanks for a great site. You saved me a $100.00 service call.
Thanks again,
Joe from Austin, IN
Aug 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sharp YO-P20 Handheld Logo
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
