Question about Samsung VP-D103i Mini DV Digital Camcorder
Memory stick eject
How do I record using memory card and how do I take out the memory card cos there is no eject.dont have a manual
Well to record onto, switch the power button to "camera mode". this will let the camera know to record as well as take pictures onto the memory stik.
As for ejecting the memory stik, jus simply push it INWARD gently and it will spring OUTWARD toward you. to put it bac, do the opposite till the card locks into place
Posted on Jul 08, 2008
How can I recover data from the Sony DCR-SR42 video camera. I set the recorder..I verified it was recording and when i turned the camera on it said "recovering" data and then no data found. Any...
You can recoverlost photos,videos from memory card or memory stick of your camcorder withthis
1. Do not save any new photos and videos into the memory card or memory stick.
2. Connect the memory card or memory stick with computer. You should see itshown as a drive letter (like H:) in My Computer.
3. Download memorystick recovery software, recommended one is Tenorshare Data Recovery(simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start'button to start scanning process which will find your lost photos and videos.
Sep 05, 2011 | Sony Handycam DCR-SR42 Camcorder
Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Nov 13, 2008 | Sony Handycam HDR-CX12 Flash Media...
Memory stick recording
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Sep 18, 2008 | Sony Handycam DCR-PC105E Mini DV Digital...
Not recording
i have a camcorder just like yours. by the way im not using memory stick because its pretty easy to use a dv tape.
try to switch from the menu your storage device like dv to memory card or stick. format it to your camera and computer. hope that helps!
CHARCOIS
Jul 28, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Sony handycam not recognizing memory stick
i think the 108 will only put pics on card- may not show card unless in camera mode-put in camera mode w/no disc and see if it shows how many avail pics-i don't think 108 records video on card
May 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Samsung scd103 camcorder memory card
From the manual:
“Memory Stick PRO” can not be used with the SCD103 MODEL.
You MUST use only a memory stick, not the PRO
Nov 18, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Samsung VP-D103i Mini DV Digital Camcorder Logo
69 people viewed this question
Top Samsung Video Cameras Experts
Tony
Pieter Vleeshouwers
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
