Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series
Hello...I read your answer to another question and though you might have help for me in another.....How does the "mop portion" of the rainbow work? I have never gotten the results I want so I am sure I am doing something wroing.....LOVE my rainbow!! Thanks Jennifer
  • 3 Answers
You are supposed to use the hard surface cleaner solution and mix with water. Vaccum the hard surface first, then dip the hard surface attachement in the mixture (while machine is off. otherwise you will just **** up all the mixture! :) ) turn on the machine and "mop" away!! I love it!!
Posted on Jul 31, 2008
Rainbow Overflow .. HELP
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Need to replace clips that hold motor to the basin on Rainbow vacuum
There are small brass colored pin going through the latch half way between the upper portion and lower portion, where it is attached to main body of the Rainbow. Take a small nail or dowel put it directly on one end of the brass pin and tap till it comes out. Put the new latch where the old one was and insert the pin till it stops. Then tap slowly so as it pushes though the other side you can line up the hole. When the pin is flush, you are done.
Apr 14, 2010 | Rainbow Technologies D4 Bagless Vacuum
I do not have the manual to hook up carpet cleaner need help!!
I also needed a manual to answer questions that I had. I finally found after much searching an online website that actually had a manual that you can read and print out. Perhaps it will help you with your questions: Here it is:
1. [PDF] Instruction Manual that can be read – others are too small to read.
R12977A-2 PRO OM.indd
Sep 01, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series Vacuum
It's plugged!
If it happened suddenly, you have a jam somewhere. Unhook the hose to see if it's in the hose or the unit.
If it happened over time then it's likely dirty or full. Wet dirt can accumulate near the blower and inhibit suction. Cleaning the filter is almost always a good idea.
Best to you, Jidza
Jan 23, 2009 | Rainbow E series Canister Wet/Dry Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=767132
Generic problem for all Vacuums
Posted by bekahness08 on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Please state your problem… all you have is just the description of the vacuum but not the actual problem and I can’t answer the question if you don’t state the problem you are having. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Rainbow e series Canister vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=661549
Posted by tinyrose on Jun 10, 2008
I am looking for a repair manual for this vacuum. Just stopped working and will not turn on. Can you tell me where to get a manual? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The best way to get a Rainbow E Series owner’s manual is to contact the Rainbow website and or factory and give them the model and serial # for the item and you may be able to download the manual from the website or the might have to mail it out to your home USPS. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
RE: Installing rainbow E series water pan latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=652000
Posted by bettyannsoto on Jun 06, 2008
Need to know how to install rainbow water pan latch and spring latch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow latch can be replaced but I believe it is a pop rivet that holds and replaces the old latch and to replace the new latch, I have seen it done but if you don’t have the right tools you may want to contact your local vacuum cleaner dealer in your area, it can be done. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=651990
Rainbow E series
Need to install rainbow side water pan latch and spring. How to do it?
Go Ahead. Use Us.
Is there suction at the vacuum, without the hose hooked to it? If there is, then your hose may be clogged, if not, it is possible that the corrugated filter may be clogged up. You would have to remove the top to get to it.
Jan 08, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
90 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
