Question about Canon Pixma iP6600D InkJet Photo Printer
PRINTER ERROR CODE 6A00
Hello i have a problem with my printer it indicates error code 6A00
  • 1 more comment
  • ion_ditoiu Jul 13, 2008
    The printer would not start printing. Instead, the power light and alarm light are flashing alternately. I tried to torn the printer off, then unplug it, then plug it back and turn it on, but the problem persist.
  • Anonymous Jul 18, 2008
    still have this problem ERROR CODE 6A00
  • antbar Aug 12, 2008
    I had an ink spillage and in the process of cleaning this up I removed the ink cartridges and soaked up the excess ink with tissue . It was not the right thing to do it seems.When I switched on I had error notice 6A00 on the screen. I have tried switching off and on to no effect.
  • 4,041 Answers
Hi
Good Luck
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Canon mx850 Error code 6A00
Hello thank you for using FixYa.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MX850 Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly,where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you will find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
For Further assistance, I am here to help.
Thanks and Keep exploring FixYa
Mar 25, 2011 | Canon PIXMA MX850 Multifunction Printer
ERROR CODE 6A00
A600 error
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you
Jan 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Erro 6A00
The 6A00 is a Canon code for paper path jam. In the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 .
The purge unit is stuck and not able to move freely .Move the purge unit back and forth for around 10 times and then restart printer ,it should work fine .
If you still get the error code then purge unit needs replacement.
Hope this helps .
Mar 27, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have a new canon MX850 all in one printer. Only had it a month and an error code 6A00 has come up on the LCD screen.
Error code 6A00 indicates purging operation error. Please observe purge unit first, it's located in right inside the printer. Is there broken paper disturb its function?. If there is no another material out there,means purge unit is faulty and you need to bring you printer to nearest service center.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Show the code 6A00 and the printer won't print. The lcd reads check printer then flashes 6A00
That error indicates a sheet feeder error, apparently its not something you can fix yourself and you will need to send it in for repair.
You will need to send it too an Canon approved repair center, calling Canon and asking them should reveal where to send it.
Aug 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Turn printer on and error comes up 6A00
Dear barryl,
Error code 6A00 indicates that something wrong with the purge unit of your printer. It may be need replacement. I suggest you to take your printer to nearest service center.
Regards,
Nov 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Sep 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
6A00 error
This error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
hope this helps...
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
102 people viewed this question
old marine
old marine
