Question about Canon PIXMA iP4300 InkJet Photo Printer
Not sure if you saw this comment I posted?
Thanks for all these comments: the 3/4 price for new seems to be for a new print head (quoted at USD46.95)- it would be 100% of new in UK where I live!. In either case it would be a lot to pay if there is any uncertainty if it will work.
Your 10 usd (plus 10usd mailing to UK) replacement head kit seems to be a repair kit, and is certainly a bargain price and might be worth trying, as long as it does not wreck the printer ( it still works just fine for black&white).
Any furhter comments before I try something?
Thanks everyone - Alexyxx
  • Canon Master
  • 13,433 Answers
Hey, Ok I see.
Nope, noting else the problem is the print head most likely.
Posted on Jun 23, 2008
THE LITTLE THREDDED SCEW THAT HOLDS THE BLADE IN WHEN TIGHTENED HAS BEEN LOST, CAME LOOSE WHEN WORKING ABOVE HEAD, LOST IT WHERE CAN I GET A NEW ONE.
If you haven't already got one, these folks should be able to fix you up with what you need.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 21, 2011 | Bosch 52314 144volt Jig Saw Jigsaw Tool
I need to know how to put it together I have no drictions or parts manual or safety book
Please go to this link to download the manual for your saw. You can print it from your computer printer so you'll have it available to refer to while you set it up.You may also wish to see this link to your manual. It's an excellent saw. I have been using one for over 20 years, and recommend you follow the set-up procedure carefully; then it is sure to give you years of service.
Jul 20, 2011 | Powermatic 1660802K Model 66 Special...
Need riveng knife assembly price
Go to this site, find your model, look up the manual and you'll find a parts list. Using the parts number, search the parts tab for your part and price.
Jun 17, 2011 | Powermatic 1660802K Model 66 Special...
Black ink printing incorrectly. Blank lines are showing in the middle of a line of printing. I have cleaned the print heads, alligned and calibrated. Nothing seems to work. In fact, calibrating made...
Hi
Try to clean it manually by removing the ink cartridge and then clean the print head with softcloth with rubbing alcohol. Then rub again the printhead into a plain paper until ink flows. Then try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 20, 2011 | Canon MultiPASS MP370 All-In-One InkJet...
Printed photos have white vertical lines running throughout
Those are lines where the printer heads are not printing. Since in this printer the head is part of the cartridge you must clean the contact thoroughly, verify the data cable and replace the cartridges with original new ones.
If this doesn't fixes it then the defect is in the controller of the printer - the memory buffer that stores the image when it's received from the pc and sends it one line at the time to the printing heads . This cannot be repaired - the printer is dead.
Apr 17, 2011 | HP Photosmart C4580 All-in-One - InkJet...
Rubber on wheels is shot. Where can I get new rubber?
Here are a few links to new tires for your bandsaw, available here and here and here. If you google "bandsaw tires", you'll find they are pretty widely available and may be able to come up with a better price...
May 08, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Epson C86 print head/cartridge head won't move.
Hi Beverley
There is some confusion here. You say "ink sponge needs replacing" in an Epson C86 (although you have your query posted under HP Officejet 5610!) - I presume you mean the waste ink pads. If so, you need to dismantle the printer - the pads are not under the print head but deep inside the case. I can provide all the information you need to complete this task if you really want to do it yourself. Please post a new comment requesting this assistance if you do.
Apr 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Print head carriage drive belt failure.
The 710 is a very old printer. A new printer of similar quality can be bought for less than the price of the ink cartridges in the 710.
The belt is a difficult item to replace even for a tech, if you can even find one.
I'd recommend shopping for a new printer, you'll be much happier with a more up to date one anyway.
I'm an HP fan so will recommend sticking with HP.
Good luck and Thanks for stoppin by!
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 18, 2007 | HP DeskJet 710c InkJet Printer
Printer not printing items copied from canon scanner D1250U2F
Connecting a non HP scanner[Canon] to the printer may be a software mod on the printer so that it will only work with HP devices. The only way round that if this is the case is to work through a third party software[image editor]
May 21, 2007 | HP Photosmart 8250 InkJet Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
46 people viewed this question
old marine
old marine
