Question about Bunn Pour-O-Matic VPR
Bunn Coffee maker leaks
The teflon seal that is under the washer where the pouring tray connects to the heating tank has disintegrated. Where can I get a replacement gasket for this coffe maker. it is a Bunn Pouromatic 10 cup home coffee maker.
I have searched the web but can't find any servicing Bunn Co. Sites
  • Jerry Taylor Jan 04, 2009
    Thanks for the info .I called Bunn and they sent me a free repair kit and everything is running just great. Thanks again for all your help.
    Novelist:
  • 125 Answers
Hi, you can go to www.bunnomatic.com, and select for home or commercial units, and get an 800 number to call for service and parts. If they cannot help you a appliance repair shop should be able to get you going, thank you.
Posted on Jan 04, 2009
    Scholar:
  • 75 Answers
I called Bunn and they were not helpful at all! I wound up putting silicone (it is not hot enough here to matter) on it, and after it cured, it was great! We have been using it at the Office for almost a year with no problems. I just made sure I did not get any on the part that acts as the "valve."
Posted on Dec 19, 2008
  • Gerry Haverland Jan 05, 2009
    Bunn would not sell me parts! I do not know what to do for parts, unless you try to find a substitute. I am sorry I can not be of more help there. I did finally buy another pot....and I bought a Bunn. It had lasted near 10 years. I figured it money well spent.
Leaks water
the tray you pour the water into sits directly on the tank that heats the water with a gasket between tray and tank, this gasket has worn away, Bunn no longer sends replacement gasket, I made one myself
Feb 25, 2013 | Bunn 10 Cup Home Coffee Brewer
Our Bunn model B10B starting leaking done the stainless steel cylinder. I took it apart. The part of the top tray between to two rubber washers had disintegrated. How do I get a new black top water...
The water tray is not available but we do have gaskets that usually will fix the leak. If you will call us at 800-352-2866 with the model and date code and we will be happy to assist you.
Sep 18, 2010 | Bunn BT10B Coffee Maker
Bunn 10 cup home coffee brewer is leaking from the bottom area. Any ideas on how to repair this?
These models have a plastic pour-in tray just under the top lid. The plastic on these trays gets brittle over time with the heating and cooling, and they crack where they mount to the tank. The only real way to repair this is to replace the pour-in tray, but these are not sold anywhere that I have found. You might be able to find a used one at a Bunn dealer in your area.
I have seen some people do a temporary repair by putting a washer under the mounting bolt and sealing it with silicone, but this is a temp. fix at best. By the way, the reason that the water appears to be coming from the bottom of the machine is that there is no other place for the water to come out after it leaks from the top.
Apr 22, 2010 | Bunn 10 Cup Home Coffee Brewer
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
Our coffee maker is leaking. bunn b10. i see they make a kit with silicon washers but how do i get to them to replace?
Hello, goto www.bunn.com for replacement parts. The most likely reason for the leak is the gasket between the pour tray and the tank. If you cant get parts from bunn there is a company call holiday house in cali that will sell you the parts you need. Mike
Nov 01, 2009 | Bunn B10 Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
My Bunn coffee maker boiles over the top vent
Try taking the top off the unit (3 screws) and remove the pour-in tray (1 bolt) and turn the thermostat down. Replace the tray - making sure you put the silicone washer in - put the lid on, and try it again. If this doesn't cure it, your thermostat is bad, and you need to replace the unit.
Nov 11, 2008 | Bunn GR10 Coffee Maker
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn blows fuses
This is usually caused by the tray where you pour in the water leaking where it mounts down to the tank. it's probably cracked just enough to allow water to seep out, crossing wires on top of the tank, causing a dead short. There is also a seal that goes between the pour-in tray and the tank that sometimes starts to leak. This tray can be replaced if you can find a used machine that doesn't have the same problem. Before you buy one, though, you should take the top of your brewer off, remove the pour-in tray (careful - they get brittle over time) and look on the top of the tank for signs of water seepage. If there are no signs, then your heating element is most likely blown.
Oct 14, 2008 | Bunn BT10B Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn Pour-O-Matic  VPR Logo
401 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
littlechum55
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
