Question about Lexmark Wheelwriter 3000 Typewriter
Typewriter freezes when on and i tab the spce bar, all indicator lights come on, typewriter then freezes. What do i do?
  • Lexmark Master
  • 3,594 Answers
Your description is a little vague, does it type letters and freeze when you hit the space bar or or just stop on all keys?
DickyO
Posted on Jun 26, 2008
My elderly neighbour has a sticky label stuck behind the paper roller and I don't seem to be able to life up the front of the typewriter to be able to clear it.
Depending on the typewriter model, most all have release points located on either end of the roller bar. Locate these, push forward or backward, release roller bar and lift the bar out. This would be the preferred solution, as it would make removing the sticky note far easier. These release points will look like small levers and should have directional arrows visible to indicate which directions they should be pushed to release the bar. If you cannot remove the roller bar, I suggest standing over the typewriter and use a pair of tweezers to remove the sticky note. It may take some patience, and may tear, but eventually it should be able to be removed,even if it is bit by bit. Also, with each portion removed, turn the roller bar to make the remaining part of the note more visible. Good luck.
Jan 11, 2016 | Brother AX-100 COMPACT TYPEWRITER
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
The Swintec 7040 typewriter goes a few inches to the right and stops. How do I unlock?
My best guess is that you have the R. margin set there. Go to the stopping point, press but don't hold the MAR REL key, spce to desired location, press R. mar key.
DickyO
My lexmark typewriter space bar will not work and the phrase light is stuck on
The phrase light is also the single space. If only the space bar doesn't workyou may have a bad keyboard or something under the space bar that is in the way.
DickyO
Aug 23, 2011 | Lexmark Wheelwriter 1500 Typewriter
How do I reset/unlock the tabs?
in type mode press the tab key the print hear will go to the next tab stop to remove the stop press (tab - )key then press the tab key again to the next stop press tab - again you have just removed two tab stops.
to set them you space bar to the position you need a stop and press tab + key
Mar 07, 2011 | Nakajima AE-830 Typewriter
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
Space bar
If the bar works when you hit right in the middle try reinstalling the bar the metal rod must go under the tabs on the keyboard, if it won't at all you probably need a keyboard.
DickyO
Jun 02, 2008 | IBM 3500 Typewriter
IBM Wheelwriter 1000 - How to clear all tabs
Using the space bar move the carrier (print head) all the way to the right, press and hold tab clear key and hit the return key.
Dec 14, 2007 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 3000 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
