Question about Lexmark Office Equipment & Supplies
Replaced ink cartridge closed cover and wont work says cover open on display screen
    Problem Solver:
  • 7 Answers
Try slamming it. Not too hard to break it, but try slamming the cover.
Posted on Jun 23, 2008
How to change ink cartridge in epson nx215
1. Turn on your Epson printer. 2. If a cartridge is expended, you see a message on the printer's LCD display screen. The icon on the screen indicates which color to replace. Press ink.13.7.1.jpg Start (NX210 Series) or OK (NX410 Series). If you're replacing a cartridge before you see a message on the printer's LCD display screen, do one of the following: NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press ink.13.7.2.jpg or ink.13.7.3.jpg to select Ink Cartridge Replacement, then press ink.13.7.4.jpg Start. NX410 Series: Press Setup, press ink.13.7.5.jpg or ink.13.7.6.jpg to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 3. Open the scanner. Note:
Your printer model may vary from the ones shown in this section, but the procedures are the same. ink.13.7.7.jpg Note:
Do not touch the white cable inside your printer.
Do not open the ink cartridge cover while the print head is moving. ink.13.7.8.jpg 4. Open the cartridge cover. ink.13.7.9.jpg 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.13.7.10.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) ink.13.7.11.jpg 7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. ink.13.7.12.jpg 8. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. ink.13.7.13.jpg 9. Insert the new cartridge into the holder and push it down until it clicks into place. ink.13.7.14.jpg 10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. ink.13.7.15.jpg 11. Lower the scanner. ink.13.7.16.jpg 12. Press ink.13.7.17.jpg Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. If you continue to see an ink replacement message on the LCD display screen, Press ink.13.7.18.jpg Start (NX210 Series) or OK (NX410 Series) and press down all the cartridges securely. Then press ink.13.7.19.jpg Start (NX210 Series) or OK (NX410 Series) again. Note:
If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. Caution:
Never turn off your Epson printer while ink is charging or you'll waste ink.
(Taken from the Epson online manual available here)
Oct 16, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Install ink cartridges for an Epson 315 workforce
If you do not want to go through the guide, here is a quick instruction on how to insert the ink cartridge.
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. If an ink cartridge is low or expended, you see a message on the WorkForce 310 Series LCD display screen indicating which color to replace. Press OK. If you're replacing a cartridge before you see a message on the WorkForce 310 Series LCD display screen, press the ink.9.7.1.jpg Copy button, press ink.9.7.2.jpg Menu, press ink.9.7.3.jpg or ink.9.7.4.jpg to select Maintenance, and press OK. Then select Ink Cartridge Replacement and press OK. 1. Open the scanner, then open the cartridge cover. ink.9.7.5.jpg 2. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.9.7.6.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 3. Before you open the new cartridge package, shake it four or five times. Then remove it from the package. ink.9.7.7.jpg Caution:
Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 4. Remove the yellow tape from the bottom of the ink cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 5. Insert the new ink cartridge into the holder and push it down until it clicks into place. 6. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place. ink.9.7.8.jpg 7. Close the scanner. 8. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Go through your user manual for further guide on how to install ink.
Jan 16, 2011 | Epson Office Equipment & Supplies
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
The black ink will npt come through
If you have just installed a new ink cartridge and an ink low or Replace ink cartridge message is still displayed, the cartridge may be incorrectly installed.
Follow these steps to make sure the cartridges are correctly installed:
  1. Press the On button to turn on the Epson Stylus, or (if already on) press the Setup button.
  2. Select Maintenance and press OK.
  3. Select Change Ink Cartridge and press OK.
  4. Open the scanner.
  5. Open the cartridge cover.
  6. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  7. Close the ink cartridge cover and push it down until it clicks into place.
  8. Close the scanner.
  9. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while ink is charging or you'll waste ink.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 16, 2010 | Epson Stylus NX400 InkJet Printer
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    How do I change the ink cartridges
    1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner.
    Warning:
    Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    got this from the Epson Site
    Jul 29, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    No B/W print while black cartridge is full.
    Your printer and its software will let you know when an ink cartridge is low or expended.
    If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
    NOTE:
    You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
    When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
    Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
    1. Turn on the printer.
    If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
    CAUTION:
    CAUTION:
    Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
    Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
    I HAVE NO INSTRUCTIONS FOR OPENING THE CARTRIDGE COVER ON MY EPSON rx595 PRINTER AND CHANGING THE CARTRIDGES.
    Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones.
    Follow the steps below to replace one or more ink cartridges that are expended:
    2. If a cartridge is low or expended, you see a message on the display screen. Note which cartridges need to be replaced and press OK.
    3. Open the scanner, then open the cartridge cover.
    4. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
    5. Remove the cartridge from the package, but be careful not to touch the green chip on the edge.
    6. Remove the yellow tape from the bottom of the ink cartridge.
      Caution: Do not remove any other labels or seals, or ink will leak.
    7. Insert the new ink cartridge into the holder and push it down until it clicks into place.
    8. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place.
    9. Close the scanner.
    10. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the display screen, ink charging is finished.
    Caution: To conserve ink, never turn off the printer while ink is charging. If you see an ink replacement message on the display screen, press OK and press down all the cartridges securely
    Jan 08, 2009 | Epson RX595 Photo All-In-One Printer
    Ink
    Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
    Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
    66 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
