Question about Dryers
I HAD GAS DRYER AND I JUST CHANGED OVER TO ELEC AND I WAS TOLD TO USE THE NEW 4 PRONG SO I WIRED IT IN AND I DIDN`T HAVE A ONE PIECE BREAKER SO I USED TWO 15 AMP TOGETHER AND I HAVE NO HEAT IN THE DRYER. DID I WIRE THAT WRONG OR DO I NEED A ONE PIECE BREAKER
  • 525 Answers
You need a 30amp double pole breaker and be certain that the fuse box is a grounded box, so that your white neutral wire is separated from the green ground wire.
On the dryer your wiring should be as follows:
Red.....left or right terminal
Black...Left or right terminal, (or remaining end terminal)
White...Center terminal
Green: Attached to dryer frame or chassis terminal
In the fuse box:
Black to 1 breaker terminal
Red to other breaker terminal
White to neutral terminals in the box
Green to the ground terminals in the box
If you have no green or ground terminals in the box, then the green wire at the dryer should be connected to an active ground source, i.e., a copper water line or preferrably a copper ground rod.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
Maytag Neptune dryer went from 4 prong to 3 prong...cabinet light works but dryer we won't star
It's not wired right. You're only getting 110 vac to the machine which is why you are seeing some lights but no operation. Make sure when you went to the three prong plug you connected to both 110 vac lugs and common.
Feb 17, 2014 | Dryers
Dryer is tripping all electric in the garage everytime it is put on any ideas why? (looked at plug, checked wiring, changed fuse, emptied water and fluff filter)
First of all, if your dryer is tripping ALL the electric in the garage, you may be overloading the circuit capacity of the garage service. A major appliance such as a dryer should have its own dedicated circuit. That is, a circuit that ONLY the dryer is connected to with a separate service breaker. You may not have a problem with the appliance at all. It may be just be a matter of overloading. You should have a 220 VAC circuit breaker rated at a minimum of 30 amps for an ELECTRIC dryer. Or, a 120VAC circuit breaker rated at 15 to 20 amps for a GAS dryer.
You may also want to check to make sure you have the appliance wired correctly. If this is an ELECTRIC dryer, the following link explains how the appliance needs to wired:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have a GAS dryer, it should use a 110-120VAC configuration using either 14 gauge wiring for a 15 amp breaker and 12 gauge wiring for a 20amp. The power cord should be of the three-prong variety (HOT, NEUTRAL and GROUND). The color code for the wiring is as follows:
BLACK - HOT (110-120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND (Usually wired to a terminal lug at the terminal block on the appliance)
If you're dryer is already configured with a dedicated circuit breaker, please post back with a MODEL NUMBER and WHICH fuse you are referring to that is blowing. I hope this information is helpful.
Apr 25, 2011 | Dryers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
Changed my dryer from a 3 prong to a 4 prong pig tail. I have the red w/ red, white with white, black with black and the green is grounded, but no power. Any idea what my problem is?
Should have 220v between the Red and the Black. White in the middle and the green to the case of the dryer.
But sometimes colors mean nothing because the wall plug may be
wired wrong.
Check breaker and the wall plug for 220v.
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Bosch Dryer front loading: I just recently moved and had to change my 3 prong to 4 prong cord and hooked up to new location. Dryer will not turn on or light up. Checked breaker box 4 prong terminal and new...
sounds like you wired it wrong really. Do you have 120 volts from either outside wire to the center wire on the unit, and 220 to both outside wires if not its wired wrong
Jul 08, 2010 | Dryers
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
I have a delta dc-380 planer that has a 3-prong plug (looks to be modified by last owner) and I have a 4-prong plug where my dryer is. Can you help me to re-wire the planer for a 4-prong plug? thanks in...
Is it a single phase motor model 22-680, or a three phase motor model 22-681. The single phase motor will have a 3 prong outlet where the blades are in tandem and the ground is longer than the blades so it is grounded before electricity gets to the planer. A three phase motor will have to be wired directly to your house electricity without a power cord. You will have to get an electrician to hook that up so you are within the building codes of your area.
You can get a 4 prong dryer plug from home depot and wire it. I think they cost about $15 or so. Just remove the old cord and wire the new one the same way that the old cord had been wired, black to black, white to white, and red to red. Ground the green wire to a grounded screw inside your switch box. Turn your breaker off before you plug in the new cord just in case you wired it incorrectly. Then turn the breaker back on. This way the breaker will trip immediately and you will not damage anything, MAINLY YOURSELF. 220v is nothing to sneeze at. And if you feel at all uncomfortable doing this you should probably get someone qualified to rewire it. Be safe.
Oct 15, 2009 | Delta Tools & Hardware - Others
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
Conversion from 3 prong power cord to 4 prong
have you reset the breaker?
test the wall socket with a voltmeter (250v+ ac),
looking for 220v between outsides, 110v between outside and center(both) zero between center and earth.
then check with ohmmeter, zero ohms between center and earth
many high current device switches have subsidiary fuses inside the switch box, as well as those in the breaker box
Oct 23, 2008 | Frigidaire AGQ7000E Gas Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
