Question about Janome 1600P-DB Mechanical Sewing Machine
I recently purchased a Janome1600P DB machine. I have it on my Grace quilting frame and am in the process of quilting. However, the thread keeps breaking. I have made sure the darning foot is adjusted correctly, the thread is threaded correctly and that I have the right needle in. What else could be causing this. I free motion most of my quilts and haven't experienced this before. Help!
  • elvelynl Aug 02, 2008
    Same problem. Looking for help!!!!
My sister told me the thread will break if your quilt is too tight on the frame too.
Posted on Dec 31, 2011
  • 3 Answers
Try a different thread. It may be old or dry. Even some new threads seem to be finicky.
Posted on Dec 20, 2008
2 Suggested Answers
SOURCE: frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Posted on Feb 23, 2008
Thread breakage on Juki TL-2000Qi
There are a few reasons the top thread may break.
- Check the needle plate for damage around the needle hole. Polish any burrs with fine sand paper or a needle file.
Check the hook for damage. If the hook is damaged it can cause the thread to break as it comes off the tip. Be very careful if you must remove burrs from the hook. Changing the shape of the hook tip will cause skipping problems.
Check that the top tension is not too high. The top tension should be set at a medium number
Burrs on the needle plate
Burrs on the hook assembly
Bobbin tension is too tight
Jan 16, 2012 | Sewing Machines
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
I am trying to sew a quilt on a Grace frame and the needle keeps breaking. Any ideas would be appreciated
It could be you moving the machine to quickly?
I use size 14 or 16 needle.
May 11, 2010 | Juki TL-98Q
When free motion quilting the bobbin thread loops and snarls. The machine is not currently on a frame, but I have a Grace Sturdy Light and want to put the machine in (the quilt is rolled and ready), but I...
Try threading the machine with the presser foot up and see if the loops and snarls go away.........
When the foot is down during the threading, the tension control is closed and the thread cannot enter as it should.
No tension control of the top thread and the bobbin thread cannot connect for a proper stitch.
Mar 12, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Need help in using the grace sure stitch regulator of quilting
I am having irregular stitches on the forward/backward motion. I am using a Janome 16000 P on a Gracie II frame. (I purchased this as a used productin a private sale) Do I need a darning plate to effectively use the Sure Stitch regulator in a free motion mode or with a template?
Mar 04, 2010 | Janome Sewing Machines
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Frame quilting with janome 1600 db
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Oct 03, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
320 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
