Question about Adobe Computers & Internet
ERROR "INVALID FDF" in Adobe Reader 8.x
Hi All,
I am using iText to manuplate PDF form data,
In my application (ESSP Enterpise sales and service product) user can select multiple forms and fill up those form and can submit one after another The PDF forms are fetched at runtime and some buttons like “NEXT” “RESET” “FINISHED” are generated on PDF forms At run time using javascript, all this code is working fine in the Adobe reader Version 6 but…
In Adobe reader Version 7 or Version 8 When user cliks on Next button on the PDF form to go to the Next PDF form
An error occurs “INVALID FDF”
Upon cliking Next we are retruning Modified PDF form (i.e. PDF form with some injected java script is submitted at run time)
Summary: When PDF Form with some injected java script is submitted (at runtime) it fails and throws invalid FDF exception
While the same code works fine with Adobe Reader 6.
Can any body (PDF+ javascript GURU) please help me?
I strongly belive that for each problem there is a solution and this will aslo have one. Please provide me some Detail, Step by Step Concrete Solution for this problem I will be reallly really thank full to all of you.
Please Feel Free to communicate on my personal email id
gokul.ahir@gmail.com
Regards
Gokul
  • Gokul03 Jun 23, 2008
    Well friends,
    I will be happy to pay (but not in advance) for the solution if it works absolutly fine because we have to deliver it to our customer. If possible please provide me some e-address(ASAP), where I can Drop a Detail Mail related to the problem (including screen shots and code etc)
    Regards
    Gokul
  • 108 Answers
SOURCE: c database with formdesigns
You are at least by looking at what you are trying to do familair with far more than the average user. On the other hand you have not supplied the names of what you are doing or as good a description of the problem as might be necessary to pose a meaningful solution. SO....my suggestion is you check faq's at your suppliers website, google the internet with your specific problem, and go to your O/S suppliers website (i.e. the Microsoft knowledge base) for more help.
Posted on Jan 24, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Validation using Excel VBA code
Thats a lot of form work to be expecting out of Excel. You might be better off using Access, creating a table. If you need to export it back to a spreadsheet you can. The validation controls are better in Access and don't have a lot of limitations to them.
Good luck on that
Posted on Jul 23, 2008
rmeyer
  • 80 Answers
SOURCE: Microsoft Access
You need to set up security and different profiles for different people. that is the safest way. But an easier way is to have you enter data in one form and them enter their data in another form. In their form edit the properties of the fields that you want left alone. You need to set the properties to locked in the form where they do their data entry but leave them unlocked where you do your data entry. Just creat a second form by saving the first one under a different name. Also you might want to remove the fields from the tab stop list.
Posted on Nov 28, 2008
SOURCE: There is a problem in flash when i given a PHP Submit form code.
I want support of this macromedia and corel draw flash with 8 versions
Posted on Jan 25, 2009
  • 1738 Answers
SOURCE: message: internal error occured pops up.
You will have to uninstall everything that is made by adobe. Adobe flash player, adobe active x. After unstalling that, that should let you put the adobe reader back. Then download the other program I mention earlier.
Posted on Nov 09, 2009
What must I do if when I open adobe reader it say me: invalid plugin detected. Adobe reader will quit. ????
tried up-issues (Adobe Reader 8.1.2+) and got the same error "invalid plugin detected. Adobe Reader will quit".
I fixed this error by following laborious steps described in the Adobe Technical Support Home.
Not sure if this helps you guys; but worth a try. Developers should say if this the real cause.
You can find these in the "plug-ins" folder. [C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins]
"HAEvents32.api" is the main culprit. Along that, I removed "Helmant32.api" and "Helmbkmk32.api".
Without deleting these two, an error or two might come but still PDF will work. I tried all these combinations.
Note: Delete these files if present anywhere else in the system else they recreate themselves.
Thanks every one.
Dec 11, 2010 | Adobe Computers & Internet
Whenever I try to open a pdf file it says I have an invalid plugin
Assuming you actually have Adobe Reader (?), uninstall it using the "Programs and Features" control panel. Then download the latest version (9.4) of Adobe Reader:
USA - http://get.adobe.com/reader/
UK - http://get.adobe.com/uk/reader/
Hope this helps.
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 10, 2010 | Adobe Computers & Internet
Invalid plugin detected. Adobe Reader will quit error appears, pdf not accessible
INVALID PLUGIN DETECTED.
Go to C:\Program Files\Adobe Reader 9\Reader\Plug_ins\.....delete the Babylon folder. It worked for me!
Jul 24, 2010 | Adobe Computers & Internet
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
I AM TRYING TO FILL IN AN APPLICATION FORM IN A PDF FILE AND I DON'T GET ANY OPTIONS TO HIGHLIGHT TEXTS. IS IT BECAUSE THE COMPUTER I'M USING DOESN'T HAVE MICROSOFT WORD INSTALLED?
What program did you use to open the PDF? If you opened it with the default program, you probably used Adobe Reader which does not allow you to edit PDFs. You can import PDFs into several Office suites with add-ons. For example, Open Office 3 has a PDF add-on that lets the PDF be opened and modified in Draw and Impress. There are also online PDF editors and some low cost alternatives to Adobe Acrobat is the full program that makes PDFs. PDFill PDF Editor gets some good reviews
http://download.cnet.com/PDFill-PDF-Editor/3000-6675_4-10295757.html
as does www.pdfescape.com/ (an on-line option). Please note that most will put their logo on your document as a footer or somewhere unless you use a paid version.
I hope this helps.
(word does the PDF import more easily as I recall (possibly with an add-on) but there are alternatives.)
Feb 19, 2010 | Microsoft Windows Vista Home Premium...
Adobe reader error message
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
Editable forms with Adobe reader?
With adobe profesional you can make a PDF form, and send to the recipients. They can fill the form with Adobe reader and send it to you back, but only the data will be sent to you, not all with the pdf.
You can collect the data with your adobe profesional. Your programmer of medical paperless system can make the program to put that data in your database.
Here is the simple procedure:
1. Create form: Open adobe prof, menu advance --> Form --> create new form. You will go to Adobe design to create the form, there you can also retrieve your scanned document.
Don't forget to put "submit button" and your email address.
2. Then save as pdf form. It is ready to be send to your recipients.
3. The recipients will fill the data and send to you by pushing the "submit button".
4. You will receive the data in your mailbox, as an attachment of email. You can use adobe prof to collect it, example to put it in Microsoft Excel.
Go to menu advance --> form --> Create Spreadsheet from data files. A dialog box will come out, put in the files you received from your recipients. then go on, you will have the Excel data.
For put it in your database of your system, your programmer should create a program/ included in your system's program.
For Guest, to fill up is easy, just open the pdf form with Adobe REader, fill it and click the submit button.
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
Adobe Reader
A master reset should solve the problem.
Dec 20, 2007 | Nokia 5500 Sport Cellular Phone
Open Questions:
Computers & Internet Logo
638 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
