Question about HP Officejet 5610 All-In-One InkJet Printer
Scanner I have been using my scanner successfully all weekend. Now, when I try to scan, it goes through the scanning process but what it shows me is scanned is blank/empty. Two scans ago it had colored lines through it so I guess it deteriorated over the last 3 or 4 attempted scans. How do I resolve this? Thank you - any direction much appreciated. Best, Mary
  • melorigan Jun 23, 2008
    Yes, but what is an LED failure. If it is that what should I do?
    I will de-install and re-install my printer drivers.
    Best,
    Mary
    Master:
  • 788 Answers
Can you still see light move up and down the scanner when you scan? If not then the lamp burnt out. I looked quickly for a replacement lamp and it looks hard to find. If the bulb is find then the picture pick-up element is faulty or its trailing cable is broken. If the bulb is hard to find then these parts would be even harder. There probably isn't much that can be done for you machine if it's not under warranty. If it is under warranty then don't hesitate to call HP.
Posted on Jun 23, 2008
  • Dean Joly
    Dean Joly Jun 23, 2008
    An LED is a light emitting Diode which are the little electronic lights found in most electronics these days. You scanner either uses LEDs or a fluorescent lamp to produce the light needed to scan. I very much doubt that re-installing your drivers resolves your problem. I you bet that if you did a copy using your printer the result would also be blank. Copying does not use the driver or the computer at all.
  • 4,472 Answers
Try and uninstall and reinstall the drivers. If that doesn't help it sounds like you might have an LED failure. If you need the drivers let me know.
Keep me posted,
Lee
  • Lee A.
    Lee A. Jun 23, 2008
    It is a part in the scanner that has to do with actually scanning the picture(not getting technical). When the lines show up on the scans thats when it is failing. Depending on how long ago you bought it, it still may be under warranty and you can have it serviced. Otherwise you can always pick up another all in one for about 40-50$. Then still use that printer for printing and the new one for scanning.
    Keep me updated.
    Thanks,
    Lee
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma 780 freezes on scanning
You can reinstall your scanner and try it again. If it does freeze up again then you mite just have to get a up to date scan....
Jun 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canoscan LIDE 25 using Vuescsan software
The first scan is 'pre-scan' and the second one is the real scan. The pre-scan shows you a rough image and you can check borders etc. Look for options and switch off 'Pre-scan' S. Mohan, India
Jun 03, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner is stopping during scan cycle
when you tried it on other lmachines did you load software from same source? If its a software driver problem, you can uninstall the one you have and then try getting a new copy from hp website and reinstall fresh.
If there are any known issues or updates, then the current version will be best anyway and may solve the problem.
Probably not much you can do if its a harware problem, unless its under warranty.
Char S
May 27, 2009 | HP Scanjet 5470c Flatbed Scanner
Scanned image is blank, although the page inside the scanner has text &/or picture.
Scanner contains Unlock botton below it, just unlock it it will scan fine.
Vikrant
May 08, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scanning Slides from Epson Perfection V700PRO
Hi
Please reinstall Epson Scanner software it will solve your problem
Thanks
Apr 11, 2008 | Epson Perfection V700 PHOTO Flatbed...
Solid black image with flatbed or adf
This particular scanner may not run to NTFS instructions.
Check Windows Help in my computer- for program Compatability
and try to reset the software to run as Windows 98 - it may work.
Dec 07, 2007 | Microtek ScanMaker 5950 Flatbed Scanner
Scanner won't scan
try connecting it to another computer. If it works, then it is a prblem with your computer, otherwise it is with your scanner hardware.
If you can open the scanner clean the circuit board with (Isopropyl alcohol) IPA solution. you can also try replacing the ribbon type cables connecting the print head.
If the problem arised due to dust accumulation, the above action should solve the problem.
Jan 14, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
20 people viewed this question
Ben Johnson
